Aerohawk Problems Need Help!!!!!!
AR
I just bought an aerohawk. Got it out of the box charged the battery hooked everything up. When the red light came on it works for 1min then it acts like something is interferring with it and the light goes dim and nothing works. Any suggestions on what is wrong. Is it the mixer board and if so is there any upgrades to replace it with. I never got to fly it. I would appreciate any suggestions on what it could be because I have tried everything.
RE: Aerohawk Problems Need Help!!!!!!
It sounds like either your battery is no good or it is not charged for long enough. check how long it should be charged for as some chargers trickle charge for a few hours. If you are sure it has had a long enough charge then it may not be holding its charge and need replacing.
hope this helps.
rob.
hope this helps.
rob.
