Mounting ESC to Centre Diff
Hey guys, im currently setting up my Hyper GT for speed runs, I want to mount the Castle ESC on top of centre diff, my question is... is there a ready made plate i can buy or do i have to make my own?
Regards
The Proff
UK
Regards
The Proff
UK
Mounting any electronic to the center dif is never a good idea! worse case scenario would be that the wires got tangled in the diff gear while running it. Im sure you would do want can be done to keep that from happening but still. Making a plate to mount it somewhere else would be your better idea. Stuff like that can be made easy from things you may have around the house. I cut plastic off a tool box once before that worked fine for things like mounts and battery straps. I have a gtp which has he same room on the chassis and had no problem finding a place for a monster esc . For years now i been using velcro to attach esc's and recivers to chassis. I made the battey tray from what i found in the garbage can at work
![](http://i294.photobucket.com/albums/mm111/randy135zx/Mobile%20Uploads/20160404_195354.jpg)
