New Kingtech K70 shes tiny with power
Old 09-21-2017, 12:30 PM
  #101
TimD.
My Feedback: (207)
TimD.'s Avatar
Received mine yesterday.
Old 09-21-2017, 02:40 PM
  #102
jesse2357
received mine last Wednesday #027. I hope to run it this weekend
Old 09-22-2017, 09:23 AM
  #103
erh7771
My Feedback: (30)
can these be used with the K45 or P-20 size pipe?
Thx in advance
Old 09-22-2017, 09:38 AM
  #104
why_fly_high
My Feedback: (19)
Thx in advance
Would depend on the pipe. My K45 is using a Grumania pipe that is for 40-80N engines.
Old 09-22-2017, 12:35 PM
  #105
rhklenke
My Feedback: (24)
rhklenke's Avatar
Thx in advance
Just intuitively, I'd say that definitely not with a P-20 sized pipe and most likely not with a K45 sized pipe.
These 70N engines produce almost twice the thrust of a 40N engine but with the same can and nozzle size. To do this, they have to move more air through the same opening - thus much higher efflux velocity. I would think that stuffing that much high velocity air (or trying to) through a small pipe would at a minimum result in a loss of thrust, possibly engine overheat, or worst case pipe collapse.
I would stick to a pipe designed for an 80N engine for the K-70 myself...
Bob
Old 11-01-2017, 09:59 AM
  #106
Swisstyphoon
I just uploaded a unboxing and test run video on youtube.
unfortunately rcu won't let me upload any url's until I have at least 10 posts. maybe one of you can help me out and post the link for me.
should be easy to find: youtube unboxing Kingtech K70G
hope you like it
Old 11-01-2017, 02:12 PM
  #107
70 ragtop
My Feedback: (24)
Here you go
Old 11-01-2017, 02:48 PM
  #108
Swisstyphoon
Originally Posted by 70 ragtop
Here you go
thank you 70 ragtop!
Old 11-02-2017, 09:46 AM
  #109
raydar
Here's mine as well, had to do something about the stock settings as would not start on diesel from factory. have changed very little and have a record of what was done, I was very reluctant in changing anything to be honest.
Old 11-02-2017, 09:53 AM
  #110
raydar
I will say after watching that video of yours ragtop yours starts sooo sooooo much better, are you running diesel?. Mine is no where near starting right, it barely gets a temp increase on first burn and really struggles to get past the 72 degree ramp up, takes ages and sometimes fails.
Have a feeling I am going to have to contact kingtech eventually to get it starting right.
Old 11-03-2017, 08:49 AM
  #111
Swisstyphoon
the one in the Video is mine, I run it on Jet A1.
It looks like you have cold ambient temperature in your video, that might cause a bad / longer start...
Old 11-03-2017, 09:04 AM
  #112
raydar
Cheers for the update on what fuel your using I thought it was running to clean for diesel.
Had mine out today and got it running/starting a lot better, settings are auto +1 and 68 pump ign,k. It's very close and a lot cleaner.
I am new to turbines and was wondering if cold diesel on a cold day would be a factor, today was 12 degrees C and after a few good starts on the above settings I put it back to factory auto +3 and pump ign,k 64 and it refused to start, hangs on preheat every time so a change was indeed justified and had to be made.
Ran it three different days now on the bench and feel I have made progress each time out and have a setting close enough to use now, of course would rather it just ran out the box but it did not. On the plus got quite familiar with starting a turbine.
Old 11-04-2017, 12:07 PM
  #113
TimD.
My Feedback: (207)
TimD.'s Avatar
[QUOTE=raydar;12380595]
I am new to turbines and was wondering if cold diesel on a cold day would be a factor, today was 12 degrees C and after a few good starts on the above settings QUOTE]
Yes. temp makes a difference they are harder to light off on colder days . Once lit the fuel ring and injectors are heated to atomize the fuel. You will notice once lit off. it will start consistently unless it cools to ambient temp again.
