Go Back  RCU Forums > Marketplace
Fei Bao SU-27 Jet dual turbine
Old 01-25-2020, 06:34 PM
qnel
Default Fei Bao SU-27 Jet dual turbine
Fei Bao SU-27 for Sale. $2900 reduced price to sell (saves you more than $2000)...need to get onto another project.
This is a nearly completed model. had only had one flight had to replace the nose due to an emergency landing on its belly, damaged the nose and replace with brand new from factory and repainted virtually new. replumbed the fuel tanks replace elevator servos. Just need to put your electronics receiver and just need another valve for air brakes. Has servo-operated canopy, It has 3 jetronic valves for brakes, doors and gear. Has 2 UATs. Had 2 KingTech 85s ( don't have turbines) with plenty of power.
Prefer to pick up but can arrange shipping with Marvin at the buyer's expense. Paypal accepted plus fees. Please e-mail me at [email protected] for info.
Original pricing below:
- SU 27 fuse kit . Composite Material. $2900
- Wingspan : 1,650mm (65.0in)
- Length : 2,460mm (96.75in)
- Power required: 12 to 21 kg (26 to 46 lbs). 2 kingtech 85
- Servo: Miminum 6 servos: it has Elevators: Savox 2270 HV, Rudders: MSH HV 747, Ailerons BL S3507
Landing Gear (Retract, Struts, Wheels & Brake) @ SGD 1,100.00
Air Kit (Check Valve, Disconnect, T with fitting, Brake Valve, Retract Valve, Air Line, Air Tank, Fuel Plug, Fuel with Fitting & Antenna) @ SGD500.00
Tail Pipe @ SGD340.00
Kevlar Fuel Tank @ Included
Gear Door Cylinder / Hinge Set @ SGD140.00
Speed Brake @ SGD150.00
Scale Canopy @ SGD160.00
Scale Cockpit @ SGD250.00
Installation of gear door, cylinders, hinges, landing gear & speed brake @ SGD200.00
qnel is offline
Old 04-26-2020, 05:18 PM
casheon
Default Su 27
Is it still available?
casheon is offline
