Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
JetCat Mystery - 120 or 160?
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 06-21-2024, 04:57 PM
JKEpps
JKEpps's Avatar
Default JetCat Mystery - P120 or P160?
Hello,
I purchased a used older JetCat engine a couple of years when I decided to jump into turbines. It was advertised as a P120 Kero. I've run the engine numerous times on the ground and it seems to run fine, however those runs are relatively short. enough to run through a ~20 oz. tank. My question is that the ECU V5.0W has P120 check box selected on the unit, however when I power the ECU, the GSU reports P160. Which is correct? Does it matter? Did someone just select the wrong engine in the ECU and I need to change it to 120?
Engine serial number is 0872.
Thanks in advance,
-Jorden
Old 06-23-2024, 01:51 PM
Dave Wilshere
5.0W is the earliest software to support Kero start. What max rpm is set? Picture of the compressor and tail cone…?
Old 06-23-2024, 08:50 PM
JKEpps
JKEpps's Avatar
Old 06-23-2024, 08:54 PM
Dave Wilshere
It is a P-160.
Probably the ECU was re flashed to a 160 by JetCat
Dave
Old 06-24-2024, 04:24 AM
JKEpps
JKEpps's Avatar
Thanks! That's good to know! That's too much for this Boomerang Sprint. Calls for a 80N-120N. I do have a P80, but it's a propane start. Looks like the same size can. I keep hearing about "turning down the power" on a turbine. Is that done by adjusting the Max RPM? Is that doable with this P160? If so what Max RPM would I use? Any other parameters need to be adjusted?
Old 06-24-2024, 08:53 AM
Dave Wilshere
Yes, drop the max rpm in Limits menu to 110,000 and away you go
Old 06-24-2024, 02:10 PM
JKEpps
JKEpps's Avatar
Awesome! Thanks again. Is it possible/recommended for me to update the firmware on my ECU? Are there any concerns with using a 2S 7.4v LiPo vs 6S 7.2v NiCad/NiMh?
