Welcome to Club SAITO !
Old 07-20-2024, 07:59 PM
  #55201
FlyerInOKC
FlyerInOKC's Avatar
Originally Posted by 1200SportsterRider
I ran across an image of an earlier version of the Bristol, I liked the grill and prop driver and I'll comment on my fuel tank choice. The .125" dowels for the grill are coming tomorrow from the almost everything comes tomorrow place.
Earlier Bristol
The olive drab washer will be the front of the more authentic looking prop hub, both tanks are 8oz. even though the Dubro,on the left is slightly taller and longer. The fuel line attachments line up perfectly with the hole in the firewall. The Sullivan's fuel line attachments are well above the firewall hole, they would have to bend sharply go to the engine compartment. Normally I'm a Sullivan guy all the way but not this time.
One airplane I built but never got to fly before it had a fatal accident was the Dr Michael Hawkins Dornier-D.1 from Flying Scale Models issues Sep and Oct 2006. It was the radiator that caught my eye. He powered it with an Enya .46 4C MK II.
Old 07-21-2024, 01:39 AM
  #55202
1200SportsterRider
1200SportsterRider's Avatar
Thanks Mike, I have often wondered if that name is pronounced Dornyay or Dorneer..
Old 07-21-2024, 02:28 AM
  #55203
modeltronics
My Feedback: (27)
Yes Gary
Old 07-21-2024, 04:08 AM
  #55204
Jesse Open
Jesse Open's Avatar
Pete, that was used to eject case vented products into the muffler. Never really caught on.
I am using a side tap on the velocity stack to handle case vent juice. Makes a huge difference.
Old 07-21-2024, 05:08 AM
  #55205
Glowgeek
Yep, imo that's the best way to recycle the CC vent oil. The oil slugs get thoroughly remixed before entering the intake port.
Routing the CC vent to higher up on the intake manifold (OS style) works too but can cause some sporadic running behavior (transition from idle) as slugs of CC oil enter the intake port.
One day I'll do the mod to all my Saitos.
Old 07-21-2024, 11:34 AM
  #55206
Jesse Open
Jesse Open's Avatar
One oil slug can hold back a lot of air At real low idles it can be the difference between idling and shutting down!
Old 07-22-2024, 03:52 AM
  #55207
modeltronics
My Feedback: (27)
I have a couple of these that came with 120 engines. So far I've not needed to use one.
Old 07-22-2024, 04:07 AM
  #55208
Jesse Open
Jesse Open's Avatar
Don't recall seeing those.
Have you checked it for flow and direction?
Those side port appear a lot like vacume breaker relief ports.
Old 07-22-2024, 04:33 AM
  #55209
FlyerInOKC
FlyerInOKC's Avatar
The FA-270T came with one packaged with the exhaust gaskets. If you look on Page 5 of the above manual it has the instructions for use. I guess I won't be using the nipple on the one muffler pipe to pressurize the tank.
Old 07-22-2024, 05:42 AM
  #55210
Glowgeek
I would skip using that "thingy" and instead use the conventional muffer nipple to fuel tank setup. Having muffler pressure helps to compensate for varying levels of fuel in your tank. It also allows for easily priming the engine with your finger over the exhaust outlet. Win win.
If you're wanting to keep the engine bay and the rest of the plane clean you can carefully drill and tap the velocity stack for a nipple, then JBweld the nipple in place and run your CC vent there.
Old 07-22-2024, 06:27 AM
  #55211
FlyerInOKC
FlyerInOKC's Avatar
I'll probably make something like this.
Old 07-22-2024, 07:30 AM
  #55212
Jesse Open
Jesse Open's Avatar
Did that very early on. Also did it internally, ran the tube fhru the middle of the muffler.
The stack helps in two ways, contains most of, if notvall the fuel standoff as well as handling the vent oil. Considerably less plumbing work involved.
A simple, flanged tube, soldered cleanly in place. Solid and simple.
YS 53 magnesium muffler. Inlet bushed and threaded to fit Saito exhaust. New extended tailpiece made from aluminum bar. The case vent tube runs thru the muffler.
1/8\" flanged tube. The flange is contoured to closely fit, then sweat soldered in place On exhaust pipes, hard solder on intake stacks, soft solder is fine.
90 degree fittings work well to keep things close.
Old 07-22-2024, 08:21 AM
  #55213
FlyerInOKC
FlyerInOKC's Avatar
Hats of to you! I can't fault your designs, you have a great deal of skill and resources I don't have. My design is born out of a necessity of simplicity and a minimum of tools to complete.
Old 07-22-2024, 11:17 AM
  #55214
Jesse Open
Jesse Open's Avatar
Not knocking, explaining the reasoning that affects decisions.
Most of the brass tube work uses very basic tools.
That is exactly why I show it. Meant as encouragement for people with limited access to machinery. Even then, with a little looking around, often a good lathe can be found for less than the price of some of the engines we buy.
That first brass elbow was a store bought $.35 5mm brass plug. A side hole was drilled in the side with a $2 garage sale Black & Decker 1955 vintage power drill. The hose barb was hand formed from 1/8" brass tube and soldered in place with heat from a small butane torch.
Dad always said never blame tools or bemoan the tools you may not have.
Old 07-22-2024, 11:18 AM
  #55215
Jesse Open
Jesse Open's Avatar
Saito rocker covers after 10 hours run time.
Cleaned out these covers and adjusted valves 10 hours run time ago. Home brew 14-14 methanol fuel, 30w non detergent motor oil used as ARO. Photo taken directly upon removal.
Old 07-22-2024, 11:38 AM
  #55216
FlyerInOKC
FlyerInOKC's Avatar
I didn't think you were I was just commenting on your superior craftsmanship! Though if I think about it I probably could add a tube to an existing velocity stack. Speaking of old tools I have an old 1940s Black & Decker drill with a drill press stand, it won't die. I had the replace the cord due to dry rot but she is still going!
Old 07-22-2024, 12:28 PM
  #55217
Jesse Open
Jesse Open's Avatar
Naw, I can see loads of true craft and art in many of your planes.
Tip: Don't drill the tube until after you solder the side tube in place. Then, select a drill that closely fits the ID of the side tube, using minimal pressure, and a bit of cutting oil, drill the hole carefully so as to avoid snagging and hogging through.
Old 07-22-2024, 12:57 PM
  #55218
FlyerInOKC
FlyerInOKC's Avatar
Thanks for the tip!
Old 07-22-2024, 02:28 PM
  #55219
Jesse Open
Jesse Open's Avatar
Originally Posted by HunterJoe
Does anyone know where I can get a PDF version of the Saito 270T engine? I have the engine and am looking for the manual for reference and I also need a pair of exhaust nuts for this engine, if anyone has those.
Your Saito parts left here early this morning.
Enjoy.
EDIT:
Just occured to me; I hope it was the jam nuts that you were looking for.
Old 07-22-2024, 02:41 PM
  #55220
Westley
Default Saito Engine 82GK
Please help me understand why my Saito engine uses 4oz fuel in just 30 seconds. I have checked valve adjustment .030. This is my second engine to consume very much fuel. Why?
Old 07-22-2024, 02:44 PM
  #55221
Westley
Sorry, valves adjusted to spec. .003
Old 07-22-2024, 03:05 PM
  #55222
1200SportsterRider
What size Saito engine? What prop, how much nitro?
Old 07-22-2024, 03:09 PM
  #55223
Jesse Open
Jesse Open's Avatar
Originally Posted by 1200sportsterrider
what size saito engine? What prop, how much nitro?
fa-82 gk
Old 07-23-2024, 03:06 AM
  #55224
Glowgeek
Saito never produced a glow engine that consumee 8 oz of fuel per minute when tuned properly......so
First think to check for is a leak in the fueling system. Next thing would be to start leaning the mixture screw (low speed needle) and high speed needles properly.
If you need help with tuning your best bet is to find someone locally that has 4 stroke tuning experience. If no one is available someone here can walk you through it.
Old 07-23-2024, 04:36 AM
  #55225
1200SportsterRider
How is this for similar to the early version, the FA 40-a is in there smiling. I have a more proper prop nut coming Friday
