RC Car Engines Talk about rc car nitro engines and gas engines
Rovan 1/5 scale 36cc engine
Old 08-11-2024, 09:20 PM
[email protected]
troy992@aol.com's Avatar
Default Rovan 1/5 scale 36cc engine
I just bought a used Rovan with a 36cc engine. It's and older model (not sure how old). When I try pull starting it, about second or third pull it will try and start, but kicks back and breaks the pull starter. It seems as if it has alot of compression. I'm on my 3rd pull starter and lost at what to try next. Anyone else have or had this problem? Thanks in advance for any help with this issue.
Old 08-12-2024, 07:38 AM
Tbone4life
Tbone4life's Avatar
Default Does the fly wheel match pull start pawls
Does the flywheel match pull starter teeth or pawls? Sometimes folks buy lightened aftermarket flywheels and the pull starter teeth don't match up to the flywheel or sometimes they just don't buy the correct one for that motor compression, i.e. regular duty vs heavy duty.
Last edited by Tbone4life; 08-12-2024 at 07:42 AM. Reason: added more explanation.
Old 08-13-2024, 03:16 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
It sounds like the flywheel key could be sheared, or the ignition is incorrectly setup. It sounds like the timing is off (firing too soon).
Tbone4life (08-14-2024)
