Swiwin Turbines
#226
Futaba SBUS2 telemetry issue continued
Hi guys,, sorry to drag this thread back to the SBUS2/Telemetry/throttle topic,, but!!!!
I'm installing a SW140b into a model with a BoomaRC Smoothflite16,, this uses 2X Futaba 7008 RX's for redundancy...
The problem: if you run a throttle cable from the Smoothflite16 to the PPM port, you get throttle input working fine, if you turn off the Tx, the Smoothflite16 sends a failsafe signal to the ecu to say stop, that's fine. Now you plug in your cable from the telemetry port to SBUS2 port, the telemetry works fine, but the engine has (as we know) a built in SBUS decoder, and picks out the throttle channel data streaming out of the SBUS2 port on the Rx, which over-rides the signal coming in from the PPM port. you still get throttle input, but now only from that one Rx, it stops the use of the Smoothflite16 Rx redundancy.. you are not supposed to use failsafe on the Tx, as apparently that can cause "jitters" to the Smoothflite16... so now, if I turn the Tx off, the engine won't stop, it just "Holds" idle... (by our regulations, it must stop).
Is there a way to stop the ECU from looking at the SBUS data stream for throttle input, while still streaming out the telemetry data??? OR preferencing PPM input over SBUS2 input?
I tried the SBUS Thr channel setting, hoping you could disable it,, but all you can do is select another channel...
I can't be the only one using a Swiwin with a Smoothflite16/26 or Powerbox etc etc????
Has anyone worked this one out???
Cheers
Bob Flint
Cheers
Bob Flint
#227
Cheers
Bob Flint
Cheers
Bob Flint
#228
I’d love it, if in an upcoming firmware update, that you could turn the (SBUS) Thr CH parameter to “invalid” just like the SBUS Aux CH parameter,, that way you could run throttle into the PPM port from your powerbox/Smoothflite and still have telemetry flowing out of ECU and into SBUS2 port, WITHOUT it picking off Throttle Channel data…
Futaba Telemetry…. It never ceases to trip me up,,, one way or another….
#230
AR14400T powersafe anomaly
Hi Guys , after many tests, I managed to make the swiwin telemetry work with the AR14400T, the only way is to turn on the receiver using the button and immediately after the LEDs turn on, quickly press the button again, probably doing so the simultaneity of the supply voltages occurs and the telemetry of the Xbus port starts
Has anyone else experienced the same thing?
best regard
Riccardo
best regard
Riccardo
#231
CO
Much has been written about the Spektrum Powersafe receivers and Swiwin turbines and getting the telemetry to work. I have the cable that provide power for the ECU from the xbuss cable. I get the data fields showing up on NX10 receiver screen but no data.....have all the updated software in receiver and transmitter.....I have spent significant time on this effort but no turbine telemetry......any ideas ?????
#233
Swiwin Telemetry vs Spektrum AR14400T
It's been a few months now! Anyone was able to get the Spektrum AR14400T working with Swiwin telemetry?
Spektrum IX20 Tx
Spektrum AR14400T PowerSafe receiver (up to date)
Swiwin 120B
Using BAD BOYZ RC Powersafe cable,
Still not working...
Anyone with more success!?!? Thx
Spektrum IX20 Tx
Swiwin 120B
#235
My Feedback: (41)
Do some nosing around on the radio forum at RCGroups. IIRC, there are some ECU's which will not play unless powered with the model. Since the PS rx's do not sent out a signal until they bind with the tx. The time delay was causing some issues with some ECU's. There's a work around which IIRC, involves powering the ECU when the model batteries are turned on.
#236
#238
SW300B Error: RPM Low
Hi guys. Maybe you can help me?
I have 5 planes with the sw300b engine, I fly only in automatic mode using Ardupilot and almost always (5 out of 7 times) I encounter this problem: The sw300b engine stalls at approximately the same place on the mission. In the logs I always see the same error: RPM low.
Flight parameters:
1. Take-off altitude 1300m above sea level.
2. The altitude at which the engine stalls is 4300 - 5300 meters (tried it at different altitudes).
3. Default motor settings.
4. Fuel: aviation kerosene with 5% oil.
After landing the engine starts without problems.
I tried to enable auto restart.
The engine, as usual, stalled during the flight, then tried to restart once, apparently it didn’t work and it turned off.
I didn't guess to save the logs, I just took screenshots.
Can I count on your help? Thank you.
best regard
Nicola
I can't attach screenshots...
Flight parameters:
best regard
Nicola
#240
Try reducing the acceleration value....its probably a compressor stall as the margin gets reduced as the air thins out (same as when air temperature goes up ).
BTW what are you flying ? Not many model turbines make it that high! Can you share a picture?
#241
Information from sw300b_specification: Maximum service height 8000m.
#242
Do you think the value needs to be reduced further?
Maybe need to add air intake?
[/QUOTE]BTW what are you flying ? Not many model turbines make it that high! Can you share a picture?[/QUOTE]
I can't attach a picture or link because I have less than 10 posts
#243
I used default acc/deacc values = 25/25.
Do you think that it is necessary to reduce the values further?
I can't attach a picture or link because I have less than 10 posts.
#244
Does the flame out happen at a point in the mission when there would be a throttle/RPM change? As far as I know, the ECU is not temperature and altitude compensated, so a compressor stall might be likely. Early turbojets (full scale) were very restrictive with throttle movement at altitude.
#245
Do you think it is necessary to reduce these values further?
I can't attach a pictures, i don't have enought posts.
#246
How can I understand that flame out happen?
#247
You probably are going to have little direct evidence in the ECU data log as the logging rate is slow and stalls usually happen very fast in these small engines. "Speed low" usually means the engine is not maintaing the requested RPM or RPM rate change, and the ECU shut it down. If you have live audio you might be able to hear the "POP" or rumble the stall(s) occurs.
I would try reducing you acceleration values to the minimum amount you feel is safe to fly, or see if there is a slow/very slow setting in the ECU (king tech and Jetcat have this). Retest and see how it goes.
Most of the engines I have used are sensitive to temperature and humidity and I keep the rates slow to try and get some stall margin ( I only fly in the summer when its hot).
