CARF Ultra Flash Evo build thread +
Old 06-27-2024, 09:55 AM
  #801
BDK74
Thanks! May omit them and stuff a temp probe back there to see how warm it gets.
Old 06-27-2024, 09:00 PM
  #802
Dave Wilshere
It is more important to open the rear face fuselage hole and tailcone hole around the tailpipe. The tail cone gets quite warm without the air gap.
The new Evo built in under 5 days was test run by the builder without opening that up and the tailcone got hot. Added some clearance and we ran it yesterday and it was pretty cool.
You can see he went with the NACA ducts having built previous fully ducted UF’s
Old 06-30-2024, 11:37 AM
  #803
737Driver
737Driver's Avatar
probably a little late in the game for pin removal tool idea, but I tried a jewelers common screw driver and it worked! The paper clip idea doesn’t work very well, bends to easy, but that jewelers screw driver has some rigidity to it and can pry open the lock that holds the pins in the AMP connector. Just a thought for you
Tom
Originally Posted by flaz
I'm not positive what size pins they have included in the Aeropanda set, but I suspect it's the same size I used. Digikey does offer several sizes, so you may be able to find a better fit depending on the gauge of wire used. Also, I still need to get the AMP pin removal tool. It's near impossible to remove the pins once locked into the housing without destroying them. Unfortunately the pin removal tool is rather expensive.
Oh yes, the gauge is 20-24, I'll fix the typo in my other post.
AEROSHELDON (07-25-2024)
Old 07-23-2024, 07:54 PM
  #804
BDK74
Building this all white UF. Instead of the NACA ducts I opened the ventral spine. We shall see. Using a laser level to mount the engine.
Old 07-24-2024, 02:16 AM
  #805
scoeroo
My Feedback: (9)
scoeroo's Avatar
Use of a laser -
I shot from the tail pipe down the thrust tube with a "cross-hair" beam
This way the thrust tube and engine are square & parallel
Old 08-04-2024, 01:12 PM
  #806
GREMOS
Originally Posted by jvaliensi
Hi,
I noticed my wing doesn't fit to the fuselage as nearly as good as other Ultra Flash models I have seen. There are many of them at the field that I go to.
My wing bolts are very tight and there is a considerable gap between the wing and fuselage.
How do I adjust this?
did you figured out after all??mine is also like this.....
Old 08-04-2024, 05:21 PM
  #807
jvaliensi
It was more than my OCD could tolerate, so I sold the airplane.
Old 08-04-2024, 09:24 PM
  #808
GREMOS
last might i had an epifany..i woke up and solved the issue....problem is with the screws of the wing....the part that is straight its too long....add 2 shims and problem solved.......
Old 08-05-2024, 06:47 AM
  #809
jetpower
i have the same problem
Do you have picture's please mine is also finished
Old 08-05-2024, 07:04 AM
  #810
GREMOS
check your p.m
Old 08-08-2024, 01:27 AM
  #811
GREMOS
where you guys have yor CG??i was aimming for the 235 but it end up around 220-225.....
Old 08-08-2024, 02:29 AM
  #812
robersteam
225mm works for me!!
Old 08-08-2024, 02:45 AM
  #813
GREMOS
doesn't it goes nose dive when inverted??and what about landing hadling??does it put the tail down easily??
Old 08-08-2024, 04:59 AM
  #814
robersteam
no it does not. and it lands like a trainer
Old 08-08-2024, 09:30 AM
  #815
GREMOS
well i quess i find out pretty soon....i am waitting for the unilights to finish!!!!!
Old 08-09-2024, 08:25 PM
  #816
Dave Wilshere
225mm is too nose heavy!
Old 08-09-2024, 11:55 PM
  #817
GREMOS
i am afraid that you are true......i will maiden by the end of the month when the heat will be down and propaby put smaller batterys cause i dont want to put lead in the plane.....
Old 08-27-2024, 07:46 AM
  #818
jvaliensi
I have a brand new canopy and unpainted frame FS. If anyone needs one.
Old 09-08-2024, 08:19 AM
  #819
jetpower
FINALY
after three years i had the first engine run to test the systems and all went wel.
That jetcat P130 is kickass and started without a problem.
now to final balance the ultra program deflections.
and then its time to s... my pants🤣
Old 09-08-2024, 09:12 AM
  #820
scoeroo
My Feedback: (9)
scoeroo's Avatar
No need to poop ones pants , its a very easy & forgiving jet to fly -
You'll enjoy it
Old 09-08-2024, 10:26 PM
  #821
jetpower
You'll enjoy it
i know it is just a figure of speach here in the netherlands
Old 09-12-2024, 12:35 PM
  #822
jetpower
Another question
i want art sholl super chipmunk decal's from callie graphics.
there are three size's available
witch size does fits best for the ultra?
regards peter
Old 09-12-2024, 11:04 PM
  #823
Scott Baker
1/6 size works well Peter..
Old 09-13-2024, 08:23 AM
  #824
jetpower
thank you
