H9 1/3 Sukhoi.
H9 1/3 Sukhoi.
Old 02-18-2004, 08:11 AM
FormerCA.
My Feedback: (8)
Default RE: H9 1/3 Sukhoi.
That's interesting-After reading your above post, I checked my cg reference the trim part line and that's just about where mine balances. All servos in stock location, and i've got heavy Glennis wheels.
Old 02-18-2004, 05:38 PM
Starfighter
My Feedback: (78)
Hi...Mount them on their side if you are committed to a pull-pull setup....This will ensure proper geometry in the route of the linkage...If you must mount them at the wing tube (I wouldn't, too close to engine ignition as EVERYTHING should be 14+ in. away from ignition AND ignition battery/switch to insure no ignition related trouble), you will have to use a pulley of some sort in the cable path to ensure proper geometry, and direct the cable(that's why full size acft. use pulleys in the cable runs)...I would close up the holes, mount the elev. servos in the tail, and the rudder servo in the fuse on pull-pull...My Sukhoi is rigged this way, and I have no problems with it...
