Checking RPM on a turbine?
My Feedback: (266)
I have a Simjet 3000 with no data terminal to see RPM.
I'm getting only 25lb thrust ,but at what RPM?
If the motor is not maxxed out for 25lb ,maybe it would be OK in my BV F-4?
I'm concerned of a shortened lifespan in exchange for this amount of thrust.
Can somebody tell me how to tach something over 100k RPM?
Any way to interface with the factory installed RPM sensor?
And no, Simjet STILL doesn't have any SDT available to us end users!
Jake
Jake
Jake,
I don't know the solution to your Simjet problem but.... JetCat advertises 16.5# of thrust with the P-120 it flies my F-4 very well. Tommy Woods had a RAM 750 in his several years ago maxed at I believe 22# and his flew decent as well.
David Reid
David Reid
ON, CANADA
Dump Thumbs
Originally posted by DavidR
Yup my dumb thumbs strike again.....at least it was on the keyboard and not an airplane.
Ed
Trubine RPM measurment
Jake:
I have a digital tach that can read to 200,000 rpm.
It is made by TNC of Woodstock New,York.
I will mail you later this evening with more ordering info.
Using a black majic marker, I put a small line on the machined area just behind the compressor wheel nut.
you would then set the tach to read 1 "blade" per revolution.
Done.
I just checked my 3000 and it read 122,700 and the factory spec is 122,000.
Kerry J. Sterner (Vampire)
SIMJET of Pennsylvania
Done.
