What size batteries to use?
Old 07-15-2002, 12:56 AM
sam1875
My Feedback: (62)
Default What size batteries to use?
I have a 1/3rd scale 300 - I am planning on using two battery packs with seperate switches for the receiver - 1650 NiMH. Will that be enough for 9 servos?
What are some of you all running?
Old 07-15-2002, 01:09 AM
mglavin
My Feedback: (31)
SAM
Dual 1650's is adequate for a 33% model. Just keep in mind to check your voltage prior to every flight.
I run 2700's they weight difference and cost is negligible in IMO.
SAM, please review the rules; one post per inquiry or question per member in the appropriate Forum, please.
Old 07-15-2002, 04:54 AM
BPKlein
I am flying a 33% AW Extra with 6 JR 4721's, a JR 517 on throttle and a Hitec 805 on the rudder. The plane also has two 1650mah NIMH batteries with 2 switches and 1 receiver. I usually get about a half a dozen flights with battery juice to spare.
Bryan
Old 07-15-2002, 05:09 PM
Geistware
My Feedback: (16)
You will not have a problem with capacity.
I would recommend a in flight battery monitor to constantly display the battery voltage.
Old 07-16-2002, 11:23 AM
Giant Scale
Sam1875,
I've got a 4500mah 6v nimh pack and a 2700mah 6v nimh pack in my 35% scale. Using 8 digital servos,2 switches and a jomar battery backer. Probably overkill but I'd rather have more juice than less. Got my packs from Bern at www.superbatterypacks.com and have had good luck with them so far.
Old 07-16-2002, 11:38 AM
tinman
My Feedback: (13)
Default switches
how would you hook up 2 switches....i have a zirolli at6 and want to put in the proper batteries. -Tinman-
Old 07-16-2002, 11:50 AM
Giant Scale
Tinman,
You can do it a couple of ways
1. Use a battery backer type device 2 packs and 2 switches
2. Use two switches one goes to the battery connection on the receiver, the other plugs into an unused servo channel. Packs can be different capacities but must be the same number of cell's.
Hope this helps.
