How To Finish Aluminum Gear
Old 09-30-2004, 11:35 PM
RJM
Default How To Finish Aluminum Gear
Hello,
I have just bent up a landing gear from 1/8" aluminum. What would be the best way to round the ends of the gear. What I mean by that is similar to a leading edge of a wing. Presently, the aluminum has a square front and rear and I would like to round it.
Which would work better, sanding or using a file? Or is there a better way?
Old 10-01-2004, 09:53 AM
MinnFlyer
MinnFlyer's Avatar
Default RE: How To Finish Aluminum Gear
A belt sander would be easiest, but if you don't have one, I would file first, and finish with sandpaper.
Old 10-01-2004, 05:31 PM
Strat2003
I've done it with a file, then succeedingly finer grades of sandpaper, then finishing it off with aluminum polish. You can get a mirror finish on it if you want and it looks very professional.
Old 10-01-2004, 11:08 PM
Fletch124
My Feedback: (7)
Fletch124's Avatar
bench grinder is the best idea really. what you want to do is roughly cut what you want with a band saw then work it with the bench grinder.
Old 10-02-2004, 05:09 AM
MinnFlyer
MinnFlyer's Avatar
Do NOT use a bench grinder, unless you don't mind clogging up your grinding wheel with aluminum.
Old 10-02-2004, 03:41 PM
RJM
Thanks for the tips guys. I have a belt sander, bench grinder, or many other tools including a polisher to make it look nice. Just was not sure which was the easiest to round the aluminum off.
I'll give the belt sander a try.
Thanks again.
Old 10-02-2004, 08:17 PM
martyg
My Feedback: (42)
Is powder coating a practical and/or cost effective finishing method after all that prep?
How would the finish stand up to the stresses you would see in a main gear?
Should I try rattle can paints for this application instead?
Old 10-02-2004, 08:26 PM
Dzlstunter
If you chuck the eraser end of a common pencil into an electric drill (handheld or press), you can make overlapping swirls in the finish appear "machined" (similar to the cowling of the Spirit of St. Louis--or other planes of that era).
