What adhesives do I use
Old 03-02-2005, 08:32 AM
acerpal
Default What adhesives do I use
I am in the process of building a cockpit for a P40. I will be using a variety of materials which need to be glued together. I will be using ply, balsa, styrene I have no idea of how to glue styrene to balsa or ply. Any suggestions would be appreciated
Old 03-02-2005, 09:00 AM
ifixairplanes
My Feedback: (9)
Default RE: What adhesives do I use
If it is non structural then I would use 5 min epoxy. Although recently I have discovered gorrilla glue, so I probably would be using that, it's awsome stuff!
Sean
Old 03-02-2005, 01:01 PM
TomCrump
TomCrump's Avatar
I've had good luck gluing styrene to wood with medium CA.
Old 03-02-2005, 01:17 PM
ifixairplanes
My Feedback: (9)
Isn't styrene styrofoam??? I've had goodluck melting styrofoam with medium CA!
Sean
Old 03-02-2005, 02:32 PM
Deadeye
Deadeye's Avatar
ORIGINAL: ifixairplanes
Sean
Nope. It may share some chemical properties, but it is a plastic unaffected by medium CA. Acetone will disolve it. Thin CA may disolve it as well. The adhesive that Plastruct reccomends is a acetone type solvent that bonds styrene to styrene very well. But, not styrene to balsa.
Whatever the case, you are looking at a mechanical bond. If it were me, I'd use polyurethane glue after scuffing the styrene with 80 - 100 grit. CA might fog what you don't want fogged.
Old 03-02-2005, 03:22 PM
ifixairplanes
My Feedback: (9)
Thanks for the clarification deadeye.
BTW: Gorrilla glue is a type of polyurethane glue
Sean
Old 03-02-2005, 03:29 PM
Deadeye
Deadeye's Avatar
Sean
Roger that. I think it is exactly the same from what I have read. I use the Elmers poly, and it costs about 1/3 less than Gorilla Glue. Great stuff, tough as nails, light, sandable...truly the 'ultimate' glue. Now if they could just figure out a fast dry formula...
