Making balsa stronger???
NC
Hi guys I am not getting started in rc airplane's but I am entering a speed challenge to beat the world record speed of 111 mph. Rc car action said make it creative so I was thinking I would make my chassis out of balsa. I would like to know how to make balsa very strong but yet still keep it light?
Thanks, Shredder111 [>:]
Cover the balsa with fiberglass and resin - the thickness of the cloth will determine the strength...
If you are unfamiliar with fiberglassing, do a search and you will find a TON of info... HTH.
Cheers!
Jim
Cheers!
Jim
LA
apply 2 or more layers of thin balsa, cross grain. wetting,soaking,2nd balsa with water or alcohol and apply while wet over 1st, holding in place with rubber bands, etc. may take a couple of try's. when close to your contour, then glue in place. takes time, but it works. dick
GA
ORIGINAL: shredder111
Not many ways at all to harden balsa so that suspension and other attachment screws won't pull out.
Spruce would be a much better choice.
