YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Inverted YS 110 problem, carb leaking
Old 04-22-2006, 03:59 PM
WRK
Default Inverted YS 110 problem, carb leaking
Have two YS 110 engines in different planes that have about 5 flights on them running a bit rich for breakin, after about 5 flights they started leaking fuel out of the carburetors and will hydro-lock, both engines have the recommended filters installed in fuel line and pressure line, fuel is new 20-20.
Both engines are mounted inverted, one in a new Seagull Harrier Plane and I know many use the 110 in this plane with standard tank location.
Any suggestions appreciated.
WRK
Old 04-25-2006, 11:35 AM
Dave Shadel
Default RE: Inverted YS 110 problem, carb leaking
The plunger is leaking. Try going in 1/4 to 1/2 turn on the reg screw and let me know what happens.
