Can FM & AM play nice w/ each other?
CO
HI, the subject title speak's for it,s self. Has any one had interference issues running AM along side FM,PCM,OR spectrum, or any other? The question while pertaining to AM does not exclude any problem's between other type frequency's.[sm=spinnyeyes.gif]
RE: Can FM & AM play nice w/ each other?
As as DSM (2.4GHz), AM and FM will never interfere with it. The same is true for the other way around.
I thing FM will never interfere with AM and the reverse. FM will never interfere with FM so long as you and any other driver are not on the same FM frequency. The same is true for AM.
CO
Thanks man I dont like AM but I would like to use it around other trucks planes and heli's w/o fear of jamming some one up. Still if any one has experiance w/ this would like to hear bout it.
if you have an AM radio running say channel 63 and an FM channel running 63 then no they will not work at the same time together
