Sirio 23 Air Leaks UNITE
Old 09-12-2006, 11:49 PM
  #51
bennyblanco
bennyblanco's Avatar
Default RE: Sirio 23 Air Leaks UNITE
http://www.bocabearings.com/ call them and order by phone and ask them if they fix the problem with this bearing remember they send me the wrong one the first time and tell them about my case!!!
Old 09-13-2006, 01:32 AM
  #52
willjeffw
so which one is it? size , material part#?
Old 09-13-2006, 08:42 AM
  #53
bennyblanco
just call boca and tell them you want a front bearing for a sirio .23!! i think is a 7x18x5 but dont hold me on that!!!
Old 09-13-2006, 11:45 PM
  #54
ScRacing
ScRacing's Avatar
ok lol i will and if i don't get the right one i'm coming to marrero, LA just to uhhh....visit savage 27...
Old 09-13-2006, 11:54 PM
  #55
ScRacing
ScRacing's Avatar
Can you get a part number?
Old 09-14-2006, 08:54 AM
  #56
bennyblanco
sorry i have no part#
Old 09-16-2006, 11:20 PM
  #57
REVOTMAXX.O.S.18
ORIGINAL: 408Revo
hi
i also need to get the front bearing for my sirio
but before i do that i need to pull my old one out first
the problem is the rubber that seals the bearing came of
so when i pulled the crankshaft out the center piece of the bearing just fell out
now im left with a hollow bearing and i cant think of a way to pull it out
any help would appreciated
thanks
Try heating block in oven to 270 to 300 degrees, then try to slam block
on a piece of hardwood, if lucky should fall out. Can try again
@ 325 if first time doesn't work.
Old 09-17-2006, 08:50 AM
  #58
Nathan9492
Nathan9492's Avatar
hmm so many air leaks on these engines
Old 09-17-2006, 05:45 PM
  #59
REVOTMAXX.O.S.18
I am also having air leak issue's with a 2.5R and a 2.5 my OS .18TM is fine, I think Traxxas motors are pretty much junk>>???!!!!
Old 09-25-2006, 10:06 PM
  #60
ScRacing
ScRacing's Avatar
ok Everyone the , go get boca barings, you need 7x17x5, the part number is 697, i ordered mine tonight.
Old 10-02-2006, 10:32 PM
  #61
bennyblanco
ScRacing i just found out that the sts.28 and the rb .23 front bearing fits the sirio .23 i dont know if you know it but just letting you know later!
Old 10-02-2006, 11:00 PM
  #62
aznherb36
ORIGINAL: savage.27
bocabearing over charges cause is a better bearing! but im going to order from kyosho thanks for the info!!
+1
manufactures usually always have a weak spot in engines and its usually the bearings. Dont skimp out on engine bearings. and plus its safe than sorry
