RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
Servo speed question
Old 12-12-2006, 11:38 PM
Drak55
Default Servo speed question
Ok stupid question I guess but whats a faster servo speed .08 or .13 sec??? I see some servos like KO Propo for $158. that are .15sec and then I see some that are $87. that are .08sec whats the faster of the 2?
Old 12-12-2006, 11:46 PM
Nomadio_Sales
Default RE: Servo speed question
0.8 is faster. BUT is it faster to 40, 6O or ?? degrees? Then on what voltage
Old 12-12-2006, 11:49 PM
Drak55
it said 60 at 6v
KO PROPO PDS-2367 ICS
Item is available.
$154.99
Description
The new PDS-2367 ICS servo is a new improvement over the previous PDS-2365. The updates to the servo include, hardened gear pins, more rigid servo case, FETs in the servo have been doubled and new stronger motor for better holding power. Hybrid gears and bushing upper case are still included and ICS programming can also be set via PC interface or hand held programmer (not included). Speed: 0.10 sec @ 60deg Torque: 160.1 oz-in (11.6Kg-cm)
Old 12-13-2006, 10:24 PM
tadecker
The faster servo may have alot less torque. When comparing servos you need to worry about torque that can handle the job, then worry about how fast you want it to do it.
Old 12-13-2006, 10:25 PM
tadecker
Old 12-14-2006, 07:58 PM
JRexA
JRexA's Avatar
The 0.08 servo wouldn't happen to be the Thunder Tiger ACE DS1015?
0.08 at 45 or 0.108 at 60 at 6V and 14,5KG/cm torque at 6V?
In Europe it is considered to be (one of) The best Throttle/brake servos for large Scale petrol RC cars.
Old 12-14-2006, 10:27 PM
Drak55
ORIGINAL: JRexA
Nah both servos that I was looking at are Ko Propo1 is a high torque and one is a high speed the high speed is I beleave .10sec and the high torque is .08sec thats what I dont understand why would the high torque be faster than the high speed on.
Old 12-15-2006, 10:01 AM
tadecker
How many degrees does it throw in .08 sec. may only go 45 degrees where as the high speed may be going 60 degrees in .1 sec.
Old 12-15-2006, 01:55 PM
JRexA
JRexA's Avatar
The KO PROPO PDS-2367 ICS is the High-Speed one
The KO PROPO PDS-2368 ICS is the High-Torque one in the same series
Other servo series will have other motors and different electronics, and there you might find a High-Torque servo that has more speed but less power. But the High-Torque designation is compared to other servos in the Same Series.
I haven't found any KOPROPO 0.08 serve with more torque than 111 oz
PDS-2367 ICS 6V 160.1 oz 0.10 S @ 60
PDS-2368 ICS 6V 194.4oz 0.15 S @ 60°
Specs taken from: http://www.kopropo.com/servos.htm
