HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
motor mount
Old 03-28-2007, 07:17 PM
savagecommander
Default motor mount
can a loose engine mount screw create RF interferance?? i was running it for about three tanks when the failsafe would not let up, and it would only glitch when the motor was running....
Old 03-28-2007, 07:29 PM
DamageIncorporated
DamageIncorporated's Avatar
Default RE: motor mount
What type of radio are you running? Are your batteries good and charged? Low batteries will cause a weak signal which could cause this. It's highly unlikely that a loose screw is causing your fail safe to wig out.
I do not have first hand experience, but I have also heard that an external fail safe can be a demon all on its own.
Old 03-28-2007, 07:50 PM
NitroVenom
NitroVenom's Avatar
To tell you the truth I hate failsafes because they mess up the electronics. A loose screw would have no effect on the failsafe. Check your batts and your rx antenna and make sure its not cut off. Afterwards take out the failsafe and put the truck on blocks. Then run it so the wheels can move freely. Walk as far as you can go until you cant get a signal or it starts glitching. If its still glitching without the failsafe then you might have a problem with your reciever or you need to change your crystals because of maybe phone lines or power lines. This happened with my stock radio. If it dosnt glitch then throw away the failsafe or send it back to the company if its under warranty.
Old 03-29-2007, 01:31 AM
amwhite2005
Make sure you havent accidently crushed any wires when you put the radio box lid on!
