Crawler Idea
NV
RE: Crawler Idea
I do not know much about the lunchbox's, but any truck can be made into a crawler if it has solid axles and shock mount locations. You are going to have to stretch the wheelbase with new links and add longer shocks like the T-Maxx shocks. If you do chose to build one do a build thread! It chould be very interesting!
ON, CANADA
RE: Crawler Idea
You could but it will take some custom work..........like using the rear ends from two LB's, modding one or both ends to be able to steer, building a frame and setting up suspension, steering linkages. More work then you want to do unless you already have two and a bunch of parts sitting around.
