real flight simulator
I just bought an older real flight g2 sim. it came with the old 15 pin game port which my computer does not have. So i purchased a super joy box 6 usb gameport adapter. Plug it in installed the g2 and know my computer wont reckegnize the controller in reckegnized the usb but i get an error that says the joystick has not been configured,any one no how i can get my computer to reckegnize this?
My Feedback: (13)
RE: real flight simulator
I just bought a used G2 also. It has the old 15 pin game port, a Radio Shack USB/gameport converter, and the Interlink Controller.
First thing to do is upgrade to the last G2 version - .723. You need the original CD serial number and for the seller to call Real Flight to clear that serial number. Then you can register yours and get the update free. After I did that, the sim loaded up just fine.
If you already have the last version and it still does not work, let me know. There may be something else I did that might help.
My computer does not even have a gameport, but the USB converter works just fine.
Brian
Brian
KS
Realflight actually has some G2 tech forums on www.knifeedge.com
You might give that a shot too.
-Eric
Edit: Direct link... http://www.knifeedge.com/forums/foru...00a72e879&f=41
-Eric
i went to the knife edge site and someone has a link posted to go to so i can get xp to recignize my controller but everytime i click on it page wont open. the game it self installed great but my real flight controller wont work. in my controlle panel it still says not conected?
GA
I had a similar problem with a Dave Brown simulator. I ended up buying a $40 sound card that had a 15pin gameport on it. Mine is called a Turtle Beach Riveria from Best Buy.
My Feedback: (13)
My G2 installation had a similar problem. One thing that seemed to fix it was
Open the RealFlight.ini file using notepad. Insert the following two lines after the [General] section
[Controller]
JoystickID=0
Save the file.
Run G2.
It seemed to work for me, but who knows??
Good luck,
Brian
[Controller]
JoystickID=0
Save the file.
Run G2.
Good luck,
Brian
Does anyone have a used Real Flight G2 they are interested in getting rid of??
you can respond to this or email me at [email protected]
yeah i have the older g2 if have to install the update after install the game cant run the game tell after the update and the go add hard ware on your c:\ in the dr.. that the game is in you well find the driver to still to get it working i had to call them to find out how to get it working but after that works raelly good and thats the old 16 pin or what ever it is
