Differental Question
Old 04-09-2003, 05:51 AM
Brodie Sinn
Default Differental Question
Ok when my truck was new (XXX-NT) when I spun a rear wheel the other would go in the opposite direction, after I replaced my diff screw when I spin one now they go the same way. I just opened it all back up and regreased everything really well and put it all back together and they both still spin the same way? How do I make them go opposite again?
Old 04-09-2003, 05:53 AM
droopy316
mmmmm yeah id just buy a new 1
Old 04-09-2003, 06:01 AM
Brodie Sinn
Did you even read my post? :stupid:
Old 04-09-2003, 06:03 AM
droopy316
umm yeah you replaced a screw and now its broke again
man have you ever ummm nevermind you dont like me lady
Old 04-09-2003, 06:04 AM
droopy316
how the heck are you changing the tag underneath your name
droopy316
and what is minicoiapoo or whatever
Old 04-09-2003, 06:06 AM
Rex2342
Rex2342's Avatar
Brodie sinn,
as long as one wheel spins if you hold the other and its got plenty of grease it should be fine. Just run it around for a while to see if the diff will losen up
Old 04-09-2003, 06:08 AM
SlingItX
Default Less Grease?
You may want to try less grease instead of packing it... you may inadvertently be locking the diff by doing this.
-SlingItX
Old 04-09-2003, 06:27 AM
Brodie Sinn
Ok, ill try that and maybe a lil less grease, thanks guys
and no its not broke again...... Ho0k'd Un Fonix
Old 05-01-2003, 01:25 PM
ManicMechanic
Hi Brodie,
I know your post is a few weeks old, but I wanted to see how you got on. I have a Pirate Monster and I stripped the planetary gears in the diff. I stripped it down, replaced the gears and packed it with 7000wt diff oil. The same thing was happenning to me, if I turned one of the shafts, the other turned the same way, whereas before they spun in opposite directions. I stripped it down and emptied a bit of the diff oil out, it helped but it still wasn't great.
I've put it all back together and taken it for a brief spin and it seems to be ok but I wanted to see if you'd had any probs or whether it had just worn in so to speak.
ManicMechanic........
Old 05-01-2003, 02:18 PM
mikesnitrorush
ya it sounds like now you have a fully locked differential
