decent radio??
decent radio??
Old 04-29-2008, 07:22 PM
mctyier
Default decent radio??
Hey guys, I have an expresscraft osprey boat with a 30cc gas engine in it. I took the older futaba radio out of it because the battery clip broke and it was just outdated. I put a newer futaba 2 channel radio that I had sitting around and it has the same onboard 4 AA battery setup in it. The throttle works fine, however the large hi-torq steering servo barely moves. I am not smart when it comes to the radio/ electronics thing. Could anyone give me a suggestion or ideas?? THANKS
Old 04-29-2008, 07:28 PM
Dan S
Dan S's Avatar
Default RE: decent radio??
Was your 1/4 scale servo working fine before switching radio?
I also prefer to use a 5cell hump pack for power.
Dan
Old 04-29-2008, 07:42 PM
mctyier
yes, it was working fine. The radio is a futaba 2 channel am radio- would that make a difference?
Old 04-29-2008, 08:17 PM
Dan S
Dan S's Avatar
you mean you have switch from an FM to AM Tx and Rx?
if thats the case there should not be any problem.
I am wondering, if the Rx you have put in is limiting the voltage (BEC) and only sending 4.8volts to the servo instead of 6 volts???
Now the standard size servo won't have any problem working on 4.8V but for a 1/4 scale servo however 4.8V is low.
Dan.
Old 04-29-2008, 11:44 PM
Ron Olson
Ron Olson's Avatar
If the RX has a 3rd channel on it, plug the battery pack into that instead of the normal slot as the BEC with limit voltage. Next, move up to a 5-cell pack instead of the 4-cell. Big servos eat the juice.
AM radios usually aren't the best choice for a gas boat as they're more prone to picking up interference from the ignition system.
Old 04-30-2008, 12:00 AM
mauian
Futaba 2.4 ghz would be a good investment, not too expensive and works perfectly and never worry about who is on what frequencie. I think Tower has then for under a 100.00 bucks.
Old 04-30-2008, 10:10 AM
mctyier
Thanks guys, Ill just leave this radio for the cars and invest in a new one for the boat. Apreciate your help
Old 05-01-2008, 01:44 AM
Tell 1uk
HI go for the futaba 2.4ghz not the spectrum there has been issues with this unit on water.
