kyosho mad force axles+tube chassie= great crawler?
Hey guys I am making a supper class rock crawler and I was woundering if the kyosho mad force axles would be a good axle for a wide rock cralwer. I'm using a traxxas e-maxx tranny with dual motors.but would the axles be to beefy and heavy for my engines.I'm thinking about making the rock bull chassie just wider. Hoping to get 90 degrez or over in arteculation.If you could help me post photos or anything would be great.
,thanks
,thanks
MO
RE: kyosho mad force axles+tube chassie= great crawler?
The Mad Force axles will work well. Limit your travel to around 60 degree's and you'll be much happier.
MO
Articulation is WAY over rated and when taken to the extreme (90 degrees) it will work against you and cause your rig to handle horribly.
But if you need to learn on your own, I understand.
