Hobbyzone Super cub
Hobbyzone Super cub
Old 04-25-2009, 08:03 PM
Encoder2002
Default Hobbyzone Super cub
I have a Super cub, and when I test it on the ground from about 30ft away. I run the throttle up and it will run for a few seconds then looses power. It takes 10 -15 seconds to pick the signal back up. So what I'am getting at is something is wrong, and I don't do what to replace. Thanks
Old 04-25-2009, 08:39 PM
basman
Default RE: Hobbyzone Super cub
Need some details RX TX Motor, are you 2.4 or 36meg are you range testing ??????????????
Old 04-25-2009, 08:40 PM
basman
Is it a park flyer ??????
Old 04-25-2009, 09:55 PM
rgm762
try turning the ACT off on take off, it messes with mine and make sure there is nothing on the sensors
Old 04-26-2009, 09:52 PM
RedGN
RedGN's Avatar
Does it loose power or does the motor cut out?
You have to be very specific if you want your problem solved.
Make sure the battery is fully charged.
