FAN VOLTAGE??
RE: FAN VOLTAGE??
most 12v fans can run on as little as 3 or less volts (not strong thou) you can do a few things, you can place it in the rx space labeled batt, you can draw off your pack, if your esc allows you can plug it in there, or you can run a seperate 9v batt to it and strap the batt in a free spot on either the chassis or body
