team losi ...XX?
Old 07-02-2009, 04:39 PM
justanotherguy
Default team losi ...XX?
Not alot of info around, is this a current model, or is it XXXnow?
A friend has one, hasnt used it "4 or 5 years" and I am wondering what it is worth, and what can be done with it..IE is it obsolete etc?
I know his batteries are likely toast.
Thanks for your time
Tony
Old 07-02-2009, 05:08 PM
Chris_RC
Chris_RC's Avatar
Default RE: team losi ...XX?
The current model is the XXX-CR. The original XXX came out in 2000. I would say the XX would be form 94-98 as losi was testing for the XXX in 99.
Old 07-02-2009, 05:26 PM
justanotherguy
Thanks!
Isaw a badge on it that had '97 on it, like he raced it in an event or something. Thing is he 'guessed' it was 4-5 years old..
I probably wouldnt pay alot for it then....
Tony
EDIT: He just emailed that it IS a XXX ..Still lost on value..
Old 07-02-2009, 05:35 PM
Chris_RC
Chris_RC's Avatar
I would need to see pictures of it. There is the XXX Spec, XXX, XXX BK1, XXX BK2, and XXX-CR.
Old 07-02-2009, 05:40 PM
justanotherguy
Whew!
Maybe I can convince him to let me take the box and screw with everything.I imagine the batteries are shot, he claims 45 mph though..
Old 07-02-2009, 05:41 PM
Chris_RC
Chris_RC's Avatar
Sure.......I need to see some pictures though.
Old 07-02-2009, 05:42 PM
justanotherguy
Thanks x 10!
Ive been wanting to pick up an Erevo 1/10 or 1/10 just to scratch an itch...This might be way cheaper
Old 07-03-2009, 06:09 PM
justanotherguy
Wow, we ran it, pretty neat 2wd buggy. Kinda quick, I would be hard pressed to guess a speed though. It sure didnt last long, 10 minutes at the far most.
2000MAH pack, and its OLD.
heres some pics.
Old 07-03-2009, 06:12 PM
Chris_RC
Chris_RC's Avatar
No pictures.......
Old 07-03-2009, 06:58 PM
justanotherguy
Thought I uploaded them ?
Anyway it was quick but not fast , if that makes sense...Iimagine those are NIMH's ? And I hope new packs come bigger than 2000MAH.....
WhenI settle on a truck Ihope for like a 30 minute run time, 30-40 mph.
Leaning towards an ERevo 1/10 or 1/16
Tony
ID:	1229272   Click image for larger version
ID:	1229273   Click image for larger version
ID:	1229274   Click image for larger version
Old 07-03-2009, 07:12 PM
Chris_RC
Chris_RC's Avatar
That is a Losi XX-T CR. It is a good car. You can get a 5000mAh battery which will give you alot more runtime and ALOT more power. Do you have any other information on that motor? It should say the amount of turns and brand. You want to clean that out with break cleaner or motor spray and it will run faster. How much does he want to sell you the car for?
Old 07-03-2009, 08:03 PM
justanotherguy
Again thanks for the time to reply.
No price, he wants me to make an offer. In that resepct I havent a clue. The motor was pretty warm after playing with it...
lemme ask you this :Would this thing on a 5000mah pack be on par with a New 1/16 Erevo on one stock NiMH.
I just want something Ican run for a decent time,and I am not sure of the XX's top speed.
Old 07-03-2009, 08:22 PM
Chris_RC
Chris_RC's Avatar
I would offer him $40 and just say that this car ahs 1 major revision (the XXX-T) and 3 minor revisions (MF1, MF2, CR) so just try to explain that it isnt really worth much. The way the car is setup (springs, soldering, etc.) I can tell that it was raced so I would buy it. About the speed, it really depends on the motor. Do you know what the motor says on it and maybe the amount of turns and how dirty it is? With a decent motor and good battery it should go about 35mph, about the same as the mini e-revo. The e revo will be alot smaller though. I would buy it cheap and see if you like it. If you dont, then you can sell it and buy the 1/16 e revo. Runtimes should be about 20 minutes.
Old 07-03-2009, 10:18 PM
kistner
My Feedback: (10)
kistner's Avatar
I would guess a little more run time with a 5000mah battery, wouldn't you (chris). I get a half hour or more with my 45000mah, although I am geared way low. I had an xxt a while ago, bought it for $30. It needed a few repairs, but nothing major. came with motor and servo, no radio gear
Old 07-03-2009, 10:31 PM
justanotherguy
Thanks so much you guys...I will have to feel him out. He does have a box of stuff to go with it.....Parts, wheels etc..
Old 07-03-2009, 11:40 PM
Chris_RC
Chris_RC's Avatar
ORIGINAL: kistner
Well 20 minutes going WOT or always on the throttle most of the time. If you are just running around it is more like 30 minutes. What charger does this car come with? And any other parts in the parts box?
Old 07-04-2009, 03:18 PM
justanotherguy
Its the car, body, radio , "extra" 4 year old battery, theres a charger and car charger I believe, another set of wheels/tires...
I have asked for a list ORto borrow the box while he is gone. He lives in CA, but travels back here a bit, he'll be back end of august.
He apparently owns more than one home....
Idunno if he would take$100, but I am not sure if its worth more than that. Are there still parts available??
Ihave to factor in a couple new battery packs, unsure of cost on those 5000mah's...
Ijust know I can do a 1/16 Erevo for about $340 from the LHS, 2 packs, out the door....
Hmmmmmmmmm
Old 07-04-2009, 03:28 PM
Chris_RC
Chris_RC's Avatar
Just lowball him first and see what he says. Everything is probably worth about 80-130.
Old 07-04-2009, 11:21 PM
justanotherguy
He left for Ca, but I have access to the stuff.I will get 'the box' and take pics of whats included. Basically everything I said so far. But I will know more about the motor..
T
Old 07-05-2009, 07:25 PM
kistner
My Feedback: (10)
kistner's Avatar
i wouldn't go 100 unless the charger has some value. make sure you get a picture of that.
Old 07-12-2009, 02:52 PM
justanotherguy
SOIgot it to play around with it...It has some sort of circuit board discharger thing, a pair of old batteries (gives 10 minutes street tops, each) Car, transmitter.The charger is an MRC super brain 809, 2/4 amp...
Motor simply says 'Maxtec' no turns or anything...Looks like it could do 25 mph, hard to tell with cars around here.I paced one and it kept up but Ibet is was more in the high teens....
He called me Saturday and I asked him for a general price.
He wants to get
$350!
Holy crap! Ihave some kid offering me a nice 1/10 Erevo complete setup for that price, SHIPPED!!!!
oh well!
