Glue question
Glue question
Old 07-03-2003, 03:05 PM
Kristjan
Default Glue question
What sort of glue to use between balsa and the covering material that you iron. Problem is that ironing itself doesn`t help anymore. The special glue is gone...
So I must put something by hand there. What should it be??
Kristjan
Old 07-03-2003, 03:22 PM
Attila
"Balsarite" might help stick the covering material. I assume you are using one of the plastic shrink type material.. Balsarite is a clear, thin product you brush on prior to covering..it helps with the sticking, but don't know if it will work with what you are using..good luck..
Old 07-03-2003, 03:43 PM
smeagol
Balsaloc is used in the UK, its a heat sensitive water soluable adhesive.
Old 07-03-2003, 03:48 PM
MajorTomski
MajorTomski's Avatar
Default Re: Glue question
Kristjan
Kristjan, you can also use any wood glue, balsa right and balsaloc are just forms of this stuff. Brush a thin layer on the area you need to glue and LET IT DRY then try ironing on the plastic.
And
Just because you are a beginner, I have to ask; you HAVE REMOVED the clear backing sheet off of your iron on covering haven't you??? Not a dumb question, I've had THREE students show up at the flying field with covering applied this way. I have no idea how they get it to stick in the first place but you can do it.
Old 07-03-2003, 04:03 PM
Rodney
Use any of the alphatic resin glues. Put on as thin a coat as you can and let it dry before ironing down the covering. This technique even works over wood that has had some oil on it.
Old 07-04-2003, 06:09 AM
Kristjan
No need to worry about that. We are talking about a Messerschmitt BF-109 model that has flown already. I`t is just that small area of a wing cover had "waves" so I had to remove the cover and then put it back so it would be nice and tigtly stretched. But it seems that once you have removed the cover, ironing doesn`t help anymore. So something must me put by hand there.
Can you all get a better view now?
Thank you all for your answers.
Kristjan
Old 07-04-2003, 06:16 AM
Kristjan
PS. the Balsarite and Balsaloc are what I`m looking for, I think. But is there anything more simple and more common (eg. you use in everyday life) because I don`t think I can get those very quickly in my neigbourhood. Have to order from UK or Germany and that takes few weeks.
