2.5 to 3.3 help
RE: 2.5 to 3.3 help
If you plan on pulling off a 2.5 and replacing it with a 3.3 then get ready to replace axles and gears. I am slowly replacing them as they break on my trucks.
RE: 2.5 to 3.3 help
You can go on ebay and pick up all the half shafts ond knuckles for around 45-50 dollars new you will eventually need to i did the same conversion and believe it or not the 3.3 on the 2.5 chasis with the 3.3 half shafts and knuckles works great and seems to be faster than the stock 3.3 in my case not sure it there is a weight difference in the chasis or just the tune good luck
