Is the RCMK EVO really "that" good???
#101
Ok, you convinced me with today's run at the lake. The Evo is an engine to be reconded with. If it can push your Falcon to 63mph against a raced preped fully modded cat like it did today- you saved yourself at least $400 alone. No brainer.....
#102
Definately Leo, Luis's cat is $350 for the hull, he's running a hotpipe, a modded 6717x3 bob austin prop and a modded mrd engine. Hull difference is about $150 more than mine, pipe difference is $85.00 more than mine, the prop is about $50.00 more than mine and the mod is probably $300.00 more..... My math says right around $585.00. I won't be at the lake next weekend, i'll be on vacation in Breckenridge, Colorado....
#103
My Feedback: (20)
ORIGINAL: eengler
#104
This is a good thread for comparing the RCMKS-254 EVO versus the Zenoahs that died out.
What's the latest, is the RCMK clearly the winner between the two or is the jury still out?
Thank you.
Thank you.
#105
ORIGINAL: tennessee_
This is a good thread for comparing the RCMK S-254 EVO versus the Zenoahs that died out.
Thank you.
Thank you.
Pending how you compare modified to stock it becomes quite subjective.
* Don't let rumors or facts of a year or more ago troubles influence what you can buy here and now in 2010 .... RCMK's are the real deal ( Pun intended )
#107
I have a sick WHH Zenoah M5 (my fault) that's going to cost $150 to fix to make it like new. Is it worth it or should I put the money into a RCMK S-254 EVO?
Thank you.
Thank you.
#108
Thank you.
Thank you.
The EVO is a Very strong engine right out of the box and if in time wanting too get modified .... easy to do by yourself or nominal fee from a reputable tuner.
#109
![](/forum/images/badges/premium_vendor.png)
Thank you.
Thank you.
The option of getting a new motor is certainly more attractive than rebuilding a damaged motor. If the motor ingested debris or water (for example as I dont know what happened to yours) then you might very well have damage on your bearing surfaces on the big end or the crank bearings (among many other items). Hard to say how much it is worth spending money fixing a damaged motor (without knowing just how much damage has really been done). You only need a little bearing cage to come free and you will be spending even more money.
#110
The RCMK evo motor I received from Bruce at Gizmos is a very reliable and fast motor right out of the box. I wanted a little more and sent it back to Bruce and now it’s the one I love to run after he modded it. I own WHH M-6, QD HT 25, Butch The Boatman, and a few others and the RCMK dollar for dollar is the way to go. Very tuff motor. IMO
#112
Tough decision huh?
I saw your other posting but didn't want to step on any feet in there. The ACMB R-42 has killer looks and is as tough as nails but the price is up there also yet not bad compared to other Cat's. The Aeromrine Conquest seems to be one of the top picks for heat racing but only with the CC Racing mod of having the seams taped.
This would make a cool thread on its own if you need some help in figuring out which one you'd like to buy. Ask for what members think are good and bad about each of their choices.
I got a deal on a slightly used Scott Schneider modded RCMK and installed it in one of my Cat's. Hoo boy, is that thing fast and fun now! She didn't run too badly with a stock RCMK. No telling what's it's going to do once I really get it set up properly!
#113
NY
Nice Ron
with all the good comments ive read about the RCMK, checking out some of the other options out there really dont compare like everyone's said, more bang for the buck...........
the kewl thing is, i have time to make up my mind what cat hull i'll end up choosing.....i definitely want something i'll be able to tune in as fast as i can to blow away my brother's toy MVD and still tool around the ponds and not have to fly down the straights at 60+ when i want those 'lazy sudays'.... still, i also like the scale looks of the thunderbolt and Super Cat, and still be running a gassereither way between40-47 inches long....at least i have the time to decide while running my smaller boats, already knowing what i'm going to use asthe power plant...one thing that will help one way or another about the G2 Super Cat.....i havent seen any videos for it yet
posted to bill at Top Secret boats in another forum and all the other peeps there, that may know of one around i would be able to check out....love the look of that cat...
![Frown](images/smilies/frown.gif)
