31% Colombo Anderson Extra 300L
#32
OH
Inside of fuse, radio compartment. The big are by the rudder servos measures 7 1/2" wide at front, 6" wide at the back and 11" long. The smaller area is 7 1/2" at the back and 8 1/4" at the front by 5" long. I weighed my fuse with the wings, stabilizer and elevators, fin and rudder this evening on a postal scale acurate to .5 ounce and it weighs 7 lbs 2 oz.
Mark
Mark
#33
My Feedback: (21)
Mark, THANKS!!!! BTW, keep up the good building.
I am going to use the Pefa 75cc Tuned Canister Muffler from 3W/Cactus Aviation
Ill see what the measurements are for the can tommorow but i got to go tonight.
Steven
Steven
#34
My Feedback: (99)
Hey mark looks like you did'nt have to cut the motor box rail's down. do you have to make standoff's also. and i assume you mocked the zdz 60 up already. would be nice to see a picture of it if possible.
#35
OH
I haven't finished the engine box yet, just done alot of measuring as to how it will fit. My measurments show the 60 will mount directly to the firewall without having to cut the sides down and I won't need standoffs. I hope to have the engine box finished sometime next week, I'll post some pics when I get it all finished up.
Mark
Mark
#38
My Feedback: (21)
Another thing that I wanted to ask is I know that the Colombo Anderson models do not give you a C of G on any of there models. Widebody, Extras, etc...
So does anyone know the correct C of G or one that makes the plane fly 3d/imac well? I was wondering if the 25-27% MAC thing applies here.
Steven
Steven
#39
My Feedback: (21)
Revised Set-Up
I revised the set-up list and deleted the old one I posted to show what the new set-up is and the changes...
Description:
Firstly, CA Models wishes to thank you for choosing our Extra 300L, and we hope you enjoy building and flying your new model.
To guarantee excellent quality, we have carefully selected all the materials in your kit, like the Balsa, Plywood, etc.
Besides, like all our other kits, your Extra is kitted with the latest technology, the foam is cut by CNC, our canopies are made with special machines, our landing gear is made with using a router, and of course, our laser cutting, which guarantees the perfect aligning and fitting of each part. So good is the cutting, that plans are not even necessary during the building. The parts assemble into each other accurately.
If you find any broken, defective, or missing parts in your kit, please e-mail us, and we will replace the part as soon as possible. Also, if you need any support when you are building or flying the model, please contact us, we will be glad to help you.
Lastly, remember to spend time, to build accurately and carefully. Remember the old saying, 'Why is there never enough time to do it once, but always enough time to do it twice.' It will be faster in the end, and you will get a better flying model. Remember, these are not little toys anymore. CAMODEL SRL has no control over the final assembly therefore no liability shall be assumed for any damage resulting from the use after the construction.
Specifications:
· Wingspan: 93”
· Length: 88”
· Weight: 17-19lbs
· Power: 45-80cc
· Radio: 9 servos required (optional choke servo)
Supply List
Airframe:
· Colombo Anderson 31% Extra 300L ($415)
Engine:
· Motor: ZDZ 80 RV (own)
· Muffler: PeFa 75cc Tuned Canister Muffler ($130)
· Spinner: 4.5” Bullet Pete’s Model Carbon Fiber Spinner ($100)
· Propeller: Menz S 26 x 10 ($40), Mejzlik 26 x 10 ($59)
· Fuel:
Fuel Tank:
· Fuel Tank: Dubro Fuel Tank 950cc 32 oz. ($8)
· Fuel Tank Cap: SWB Anodized Aluminum Fuel Tank Cap ($9)
· Fuel Tubing: Slimline 1/8 I/D Premium Grade Tubing ($6)
· Fuel Dots: Slim line Fueler F1 System
Radio:
· Radio: Futaba 9CAP PCM (own)
· Transmitter Pack: PowerfLite 10.8V 1300mah Li-Ion ($100)
· Receiver: Futaba R149DP 9-Channel High Receiver ($160)
· Ignition Battery Pack: PowerfLite 7.2V 2400mah Li-Ion ($120)
· Receiver Battery Pack: (2) PowerfLite 7.2V 4400mah Li-Ion ($280)
· Ignition Voltage Regulator: Smart-Fly Regulator with Fail Safe Switch ($45)
· Receiver Voltage Regulators: (2) Smart-Fly Regulators with Fail Safe Switch ($90)
· Charger: PowerfLite Four Output 3-7.2V 1-10.8V AC/DC Charger ($190)
· Other: PowerfLite 1 Amp Load & Digital Multi-Meter ($40)
· Choke Servo: Hitec 5475HB Heavy Duty ($35)
· Throttle Servo: Hitec 5925MG Coreless Digital ($70)
· Aileron Servos: (4) Hitec 5945MG Coreless Digitals ($280)
· Elevator Servos: (2) Hitec 5945MG Coreless Digitals ($140)
· Rudder Servo: (2) Hitec 5945MG Coreless Digitals ($140)
· Power Box: Modellbau Power Box 40/24 Duralite Plus ($300)
· Switches: (3) Smart-Fly Super Switches ($90)
Hardware:
· Servo arms: (7) Sure-Link 2024-T3 Alcad aluminum CNC machined arms ($84)
· Ball links: (7) Central Hobbies Dual Axis Rod Ends ($35)
· Push rods: (6) Hanger 9 Titanium Pro-Links, Central Hobbies Carbon Fiber Rod System ($16)
· Clevises: (7) MKD Control Horn Clevis w/Ball Bearing ($63)
· Control Horns: (6) MKD Control Horns ($30)
Rudder Assembly:
· Rudder System: Sure-Link’s Noll-Boston System
o (2) 90 degree arms
o Rudder Horn
· Rudder Tray: Custom Carbon Fiber Tray
· Pushrod: Hanger 9 Titanium Pro Link
· Pull-pull Cable:
Custom Modifications:
· Firewall: Carbon Fiber laminate
· Landing gear: Graphtec R/C Carbon Fiber Landing Gear ($70)
· Fuel tank tray: Carbon Fiber Fuel Tank Tray
· Wing tube: Graphtec R/C Carbon Fiber Wing Tube
o $59.95 1.5" x 36" 6.9 oz (compare to .049 Al at 11.3 oz or .035 Al at 9.5 oz!!)
$69.95 1.5" up to 46" custom cut to any length
$8 1.5" x 36" ID phenolic
· Rudder tray: Carbon Fiber Rudder Tray
· Stab tube: Graphtec R/C Carbon Fiber Stab Tube
o $1/inch .635" OD stab tube (custom cut up to 45") (can be sanded to 5/8")
$4 .635" ID stab phenolic (custom cut up to 48")
· Tail wheel: Graphtec 30lb Large R/C Carbon Fiber Tail wheel Bracket ($35)
Other Misc. Items:
· Velcro Straps: PowerfLite 12-18” PowerWrap ($1.25-1.65 each)
· Zip Ties: http://www.buycableties.com/online-catalog.html
· Foam: http://www.generalplastics.com/produ...il.php?pid=23&
· Grommets:
· Glue: Zap Adhesives
· Covering: Monokote
· Paint: PPG Automotive
· Pilot:
· Wheels: (2) Sullivan Skylite Tires ($13)
o Axels: Dubro 3/16” dia Axels ($5)
o Wheel Collars: Dubro 3/16” dia Wheel collars ($2)
Description:
Specifications:
· Wingspan: 93”
· Length: 88”
· Weight: 17-19lbs
· Power: 45-80cc
Supply List
Airframe:
Engine:
· Fuel:
Fuel Tank:
Radio:
Hardware:
Rudder Assembly:
o Rudder Horn
· Pull-pull Cable:
Other Misc. Items:
· Grommets:
· Pilot:
#41
OH
Wing root showing threaded insert.
Shortman your choice of tail gear may be overkill, I haven't bought mine yet but my brother has that very same one on his H9 Sukhoi. It seems rather large on his Sukhoi and much heavier than he neads. Also I don't think there would be room on the tail gear plate on the 31% to mount it.
Mark
Mark
#42
My Feedback: (21)
Yeah thats true, I will probably go the next size down and get that one.
Nice pictures of the wing attachment! How much is left for you to do? Get some more pictures hehehe!
Steve
Steve
#49
My Feedback: (21)
Did you have to get any extra materials when you double beveled the surfaces or just use scrap?
Your going to use the ZDZ 80 RV correct? How will this fit you believe in the cowl and what cutting will need to be done?
I'm curious to see what the weight of this plane is as all the other planes are a little heavy but still light for there size.
Steven
Steven
#50
OH
Shortman
I had to buy new wood to make the bevels. I'm using a ZDZ 60, haven't got it mounted yet but will probably have to cut out for the head a little.
