Flight Hobby Top Stage 70
RICKSTUBBZ (04-10-2024)
The fuselage sheets are now glued.
Some sending of the edges.
Glue the top cover of the fuselage.
The wood cover of the front
the main beam of the fuse bottom.
The tail bottom
Now on the fuselage. Will need some serious sanding.
Because of your build I did hop over to the "Flight Hobby" website the other day to check out what all they offered.
I was in for sticker shock when I converted the cost of their kits. And I didn't even get to the shipping part.
None the less, it sure appears to be a well engineered airplane with all the right tools available to build it square...
What is the theory on using a Canalyzer?
#34
Yes, Japanese kits are not cheap, but I enjoy the process, and F3A 70 size planes are a rare find.
The Canalyzer streamlines the slipstream on the rudder and elevator, for better stability, and knife edge flying.
#35
My Feedback: (121)
Hey Rick,
Now is the time to buy a flight hobby kit. The yen to $ exchange rate is very favorable; today about a 37% discount. I buy from RC-Japan, they are great to deal with.
Flight Hobby kits are top quality as you can see in this build thread.
T-cans definitely increase rudder authority. Pattern moving to constant, generally slower, speed; more ‘gadgets’ are needed to provide aerodynamic assistance.
RICKSTUBBZ (05-01-2024)
#36
Canalyzer on the dedicated jig
glued with the cover sheets
now need to fit it to the fuselage
I glued the canalyzer front and pins, in place, using nylon to separate from the glue.
now it is ready for the fiberglass covering
the canalyzer ready and fit in the fuselage.
ram_z (05-26-2024)
gil.s (08-20-2024)
#41
Preparing the fuselage for the cowl.
checking that the cowl fits prior to glueing
Checking the fit of the canopy base as well
Okay, glueing in progress. I used black epoxy to do the magic.
