Davette ss new toy
RE: Davette ss new toy
Mr.Freeze, Just wondering if you've run the new boat anymore. I'm looking at sometime in the near future for a new boat. I can't seem to decide between the boat you have or Dana s new deep vee. I was wondering how the boat is handling for you. Who knows maybe I'll get both. Yeah I'm sure that will go well with the wife. Also have you installed the skeg yet? If so is it self fabricated or purchaced? Let me know.
VT
ORIGINAL: ByronRC
My Feedback: (40)
Hey Guy, , Just be very very carefull when you install that damn thing !!! mMe think i made a little to sharp . LOL i got the scare to prove it . Lmk when you want to do some work on it . I'll give ya a hand . Later Bill
#31
My Feedback: (40)
Looks good. [sm=bananahead.gif] i bet it will hook up better now . How's the finger's ? did ya have anytrouble installing it ? now you can raise the out drive a bit. w/ the wieght under the motor . have fun with it . we'll get together this summer & run the Dog Piss out of a few that i got
keep us posted Later Bill
#32
VT
Ya, before I put it in I gave myself a shave LOL, no problems at all putting it in. Now that I have that 23 out I might aswell look for 26 to put back in . Also I think I'm gonna ditch the IV bag and put a tank in it. We'll hook up this summer for sure, Thanks for the help Bill.
#33
VT
Well I ditched the IV bag that was in it and put in a 24 oz. dubro tank. I spliced a tee in for a vent but I was wondering where to route it and how to terminate it.
#34
hey freeze i owned one before and 24oz hardtank is a good idea had same setup, i would recommend mounting tank alot farther forward with modded 260 front gets real lite, also 12oz-16oz weight in front helps also....
#35
My Feedback: (40)
Stan, I think your still goin to have over flow prob's w/ that setup. use a three point setup.
1 INLET
2 FUEL TO CARB
3 BREATHER
i use a nitro fuel filter for breather put a loop[ in the tbeing & mount it as high as you can
Later Bill
1 INLET
2 FUEL TO CARB
3 BREATHER
Later Bill
#36
VT
The way I set it up I have the fuel fill going into the top hole in that line I 1 tee for a breather the a second tee for the carb return, and the bootom hole I have the line going to the carb with a filter inline. In the tank the top I put a longer brass tube in and ran it to the other end of the tank and angled up to the highest point, and the bottom has a piece of tygon with a wieghted end to stay on the bottom for fuel pickup.
I don't want to mount the tank further forward as ballast as it will throw of my cg as the tank empties I'll try to keep under control with the drive and tabs.
Unfortunatly all I can do right now is theorize because everything frooze up solid around here, and if was some open water I don't want to go in it.[sm=drowning.gif]
#37
freeze i ran my motor 14 1/2 in from transom to spark plug.. dont know where your at but i need weight up front... hope it handle ok fior you
#39
ran 470/3 from (dashboata) boat was in 50mph range and wild ride ... i would kick out rudder a little and that helped a lot in turns.. once you get used to way it runs i could hang with another guy running hurricane with butch motor and those run real good, i would also recommend using rudder with 6in setback that will help in turns, thats where boat needs help...
#41
ORIGINAL: Mr.Freeze
Paging- DR. Howard, the transplant is complete.Out with the 23 in with the 26. Now I just need spring to get here.
#43
My Feedback: (40)
Looks sweet Stan, I can't wait till the ice is gone & we can meet up and do so boatin. I'll be glad to see me old davette runnin again . But now with more spuck. i'll bring the Laser
Good redo [8D]
Later Bill
Good redo [8D]
Later Bill
#45
VT
Got the boats out today
I found out very quickly that this hull does not like the mod 26. I couldn't go over 3/4 throttle without it doing barrell rolls, and that is with a skeg under her. First I ran it with the 575 prop then backed it off to the 470 and still couldn't keep in the water guess I'll be putting the 23 back in it and using the 26 for my woody build.
#46
My Feedback: (40)
Stan, just for the hell of it try it with both rudders! And see what it does !!! You got to remember it's not a deep vee. is it flippin in the turn's ?? Only ?? . Later Bill
#47
VT
No it's not flipping in the turns, it will barrell roll if I gas it going in a straight line, wicked impressive I'll tell you what. She had to be doing 50 at 3/4 throttle with the 470 prop. It's torque roll for sure. I'll try to dual rudders for the hell of it tomorrow but I don't think its gonna help. I've got the shark fin (finger remover) hanging down, the turn fin, and the rudder as deep as she'll go and it still rolls over better than my dogs. I would love to get dialed in with the 26 in it cause if I do she'll be doing 60
#48
ORIGINAL: Mr.Freeze
#49
VT
Back to the drawing board. Ran it today with the 23 back in it but with a better header and pipe, no barrel rolls but the speed was less than desirable.
