Anyone using nylon hinges without glue?
RE: Anyone using nylon hinges without glue?
I insert the hinge, drill a hole, moisten a toothpic and lightly coat it with Elmers Ultimate glue (low-price Gorilla), and insert. The glue expands somewhat to secure the hinge, as well as the pin, so there is no lateral movement...Works great.
My Feedback: (10)
I should probably change the title of this thread now to "Anyone using nylon hinges without the mess of epoxy?"
I recently wrote an article on how to use gorrilla glue to hold nylon (Dubro type) hinges for my club newsletter. If you are interested I can pm it to you. I would rather not post the article here since it may get picked up by another editorial.
ORIGINAL: SST
I used a ton of "probond" a few years back when I was making blue fanfold foam zagnuts's. I used about a third of a bottle on one the first one and almost ended up living in a probond igloo. I've always shied away from using it on hinges because I could see it expanding to form a one piece plane. Using it on the pins though seems to be a great idea, especially since the foamed up glue sands a heck of a lot easier than ca.
Thanks for idea!
Rich
Vicman,
If your willing to send it I'll certainly read it and soak it up. I certainly promise not to use it without attribution or pass it along without your say so.
Rich
Rich
#33
I touch a small drop of Vaseline on the hinge line, bend it slightly, then a squirt with a heat gun melts the Vaseline thru the hinge line, lay it on a paper towel to cool... Oil is a loser, as it stays moist and will leech out on the hinge...
#34
Just remember that, when you are testing, the hinge isn't getting all the different stresses it gets when in flight. There is a lot of vibration going on up there that is unnoticable to us on the ground. A straight pull just isn't an adaquate test. My 2 cents.
