cannisters for composite aircraft 2.6m
Old 11-17-2003, 08:33 AM
schroedm
schroedm's Avatar
Default Cannister Vents
FC26,
Here's a few shots of my cannister vents as requested.
1. Corel Draw Template in place
2. Rough cut outs
3. Dremelled to shape
4. Fuselage inside
I shall be liinng the vents with a thin wire mesh purely for aesthetics.
I'm not sure whether to try and cut some more vents further forward but I have concerns as that'll mean cutting holes near the u/c mounts etc. Anyone got any thoughts on more vents?
Mark
ID:	75319   Click image for larger version
ID:	75320   Click image for larger version
ID:	75321   Click image for larger version
Old 11-17-2003, 09:14 AM
3wExtra
Default RE: Cannister Vents
awesome! did yo get my pictures?
Old 11-17-2003, 05:45 PM
shill
My Feedback: (22)
shill's Avatar
I would be careful with the Canisters in this Plane. I know of 1 which was destroyed due to spar failure from the heat of the cans on the spars. So shielding the spars and having plenty of cooling is a must.
Steve
Old 11-17-2003, 06:12 PM
schroedm
schroedm's Avatar
Steve,
Sounds nasty!
I wasn't going to risk that possibility so I have gone a bit overbaord and boxed my spars in with 1/8" light ply - worth the 3oz I think
Rgds,
Mark
Old 11-19-2003, 03:19 AM
3DStein
I put a heat sheild round my spar, and I also recommend you put one on the underside of the tank if its over the canisters. Mine shrunk to about 3oz in capacity due to the heat.
You'll be suprised at the amount the canisters give off.
I'll post some pictures of my install later.
Old 02-02-2004, 02:05 PM
  #31
schroedm
schroedm's Avatar
3DStein,
Thanks for the heads up about the tanks - fortunately my install means the tanks sit on a lite ply plate like so...
Should be OK??
