Pilot-rc Viper 2.0m
Pilot-rc Viper 2.0m
Old 12-14-2022, 08:03 PM
  #51
karl hibbs
karl hibbs's Avatar
Mine fly's great, I have had a few problems , pipe failed 21 flights, nose gear strut has failed ( won't stay up on takeoff ) causes negative angle of attack . No problems with the gear or doors.
Old 03-30-2023, 02:50 AM
  #52
jmodguy
Default Viper 2.0 refurb
Hi all. I have been out of the sport for several years and a buddy got me back into it. He also gave me this airframe. It is pretty beat up and needs some tlc. I need some parts and the factory won’t talk to me without a serial number. I can’t find a serial number anywhere. Where is this serial number located?
Regards
Jeff
Old 03-30-2023, 04:19 AM
  #53
rchotdogpilot
My Feedback: (27)
Wish I could help more. My memory seems to think there were stamps on the wings, or some formers inside the fuse. But those could have been inspection stamps too?
Old 03-30-2023, 04:57 AM
  #54
jmodguy
This airframe has the number 73 written on a piece of tape and is on every piece. I am told that this is not the serial number. Kinda frustrating 🤷🏻‍♂️
Old 03-30-2023, 06:51 AM
  #55
jmodguy
A note I just received from Banana Hobby about Viper 2.0 parts…
Regrettably, the mold for 2.0 G1 has been damaged, making it impossible for Pilot-RC to manufacture its parts.
Old 03-30-2023, 10:47 AM
  #56
rchotdogpilot
My Feedback: (27)
How do we know if we have a G1, or not?
Old 03-30-2023, 11:20 AM
  #57
jmodguy
I have not been able to find an answer to that question…
Old 06-17-2024, 07:15 AM
  #58
A. J. Clark
A. J. Clark's Avatar
This circuit board with leads came with the new 2m viper. Haven't found how to connect the two leads coming from it. One labeled (light) and the other (gr to). The two pin connector is labeled (led) which is connected to one of three leads going to the front. The other two are labeled (gear door) and (gear light).
Old 06-17-2024, 07:20 AM
  #59
rchotdogpilot
My Feedback: (27)
I think that is for landing lights. One lead goes to your LED light controller, the other goes to your retract controller/receiver. So it knows to turn the light on/off depending on the gear position. The 2 prongs are for the LED
Old 06-17-2024, 02:05 PM
  #60
A. J. Clark
That sounds right. The other problem is the the two pin connector was connected to a lead that wasn't labeled. The other two lead cable is labeled gear light. The two leads are the light and gear motor. Not sure what it will take to see exactly where each wire goes. It I hook it up wrong light and gear motor will that cause a problem?
Old 06-17-2024, 02:32 PM
  #61
A. J. Clark
I was able to trace the wires. The board was connected to the nose gear light. The other wire labeled gear light is the retract motor.
Old 08-25-2024, 12:39 PM
  #62
Westwindpilot86
Hey everyone, the retracts on my 2m viper are absolute garbage. Has anyone swapped in electrons, and if you did, what size did you get? Thanks
Old 08-26-2024, 03:53 AM
  #63
rchotdogpilot
My Feedback: (27)
Are you using the Pilot retract controller?
The retracts themselves aren't bad. It's the controller. Let me guess. You're having issues that they don't come down, or they get stuck? If so, get yourself a Xicoy LGC15. Problem solved. Up the amperage to the the motors. Another thing that may work, but I have never tried, it get to a 3S Life. Maybe upping the voltage. If the sticking is in fact your problem.
Once I switched to the Xicoy controller. Issue went away.
