EA BDXs 2m
EA BDXs 2m
Old 02-23-2024, 09:41 PM
  #101
blackda
Here are some pics
Old 02-25-2024, 09:12 AM
  #102
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Sharp looking
Old 02-26-2024, 05:22 AM
  #103
qcsteve
I like that scheme. How many oz. are the side tanks?
Old 02-26-2024, 07:49 AM
  #104
blackda
Each tank is 11oz so 22oz total. I'm using a Swiwin smoke pump that maxes out at 620ml/min.
22oz = 650ml so just over a minute of smoke full out but expect to get a bit more as I don't typically run the smoke pump wide open
Old 03-07-2024, 06:51 AM
  #105
blackda
Almost done...some clean up to do still but should wrap up in the next day or two.
AEROSHELDON (03-07-2024)
Old 03-08-2024, 07:21 AM
  #106
blackda
Originally Posted by fierro1
Thought I would add this photo for those thinking about engine size. I suggest a light engine because you’re going to need ballast to get CG. This thing assembles super tail heavy. After a little over a half pound I’m at 23.23 lbs full UAT, empty tank, back of wing tube
I'm questioning your 67mm measurement, I get 50mm, have you flown it with this CG?
Old 03-08-2024, 01:22 PM
  #107
fierro1
Definitely use your own numbers, we are most likely using different gear. I always double check with a mechanical CG checker. My numbers are good for my plane.
Old 07-13-2024, 02:02 PM
  #108
AEROSHELDON
My Feedback: (99)
Super quick walkaround video.
Old 07-26-2024, 01:35 PM
  #109
YotaMan1985
Maidened my BDXs that I got from qcsteve last weekend. Flew fantastic and looking forward to taking it up again this weekend. Im new on here so cant post pics or videos yet but when able, Ill put some up. I also made a custom smoke tank for it that mounts under the turbine like the larger BDX.
Old 08-12-2024, 12:17 PM
  #110
AEROSHELDON
My Feedback: (99)
Maiden day went well. This is my first flight after a trim flight by my friend Chris--I've only been flying a Rebel Max so this landing was not good! The second flight video will be up in a day or so and I'll share it. Please like and subscribe to my fellow club mate's channel it helps a lot.
Old 08-13-2024, 02:22 PM
  #111
AEROSHELDON
My Feedback: (99)
Flight #2 on the plane.
Old 08-13-2024, 02:27 PM
  #112
YotaMan1985
Congrats on the maiden Aerosheldon! Looks great
Old 08-13-2024, 02:30 PM
  #113
AEROSHELDON
My Feedback: (99)
Thank you !!
Old 08-14-2024, 11:53 AM
  #114
YotaMan1985
What kind of flight times are everyone getting? Im running a Swiwin 120 and get around 6.5-7 mins depending on how I fly. Ive got my timer set to start when the throttle is over 5% and have fuel readouts through my radio. Just curious what others are seeing
