Go Back  RCU Forums > RC Airplanes > Aeroworks Vendor Forum
ProX 260 CG Notice-Please Read
Aeroworks Vendor Forum This is the place to go for all your questions concerning anything Aeroworks. Rocco, Mark, and the rest of the Aeroworks staff will be manning this forum so that they can answer all your questions.
Old 11-05-2010, 11:16 AM
Mark Dennis
Mark Dennis's Avatar
Default ProX 260 CG Notice-Please Read
Please see the attched PDF file for updated info on the CG of both the 46-60 ProX 260 as well as the 60-90 ProX 260.
Thank You,
Mark Dennis
Aeroworks
Mark Dennis is offline
Old 11-05-2010, 01:26 PM
dusty1966
Default RE: ProX 260 CG Notice-Please Read
Thanks Mark,moved mine to 5", much better.
Steve
dusty1966 is offline
Old 03-20-2011, 05:54 PM
AraTidwell
AraTidwell's Avatar
I don't know where my CG is now, but at the stock recommended CG per the old instructions, the tail sunk on landing.
AraTidwell is offline
Old 01-06-2012, 08:26 PM
DoubleDD
Link does not work for me. Even so I have tried to balance at 4" back from wing tip but no way. I have a normal servo for throttle instead of the micro thats proposed. I have almost 3oz of weight screwed to the underside of fuselage under motor and I still only get balance at about 3/4 tank of fuel????? Need some help here. By the way this is the 48" wingspan plane. Am using a Evo .46.
DoubleDD is offline
Old 01-15-2012, 11:02 AM
yaron_k
My Feedback: (45)
Hi
Can you re-post the ammendment?
PDF does not load
yaron_k is offline
Old 01-16-2012, 08:00 AM
Aero-Works
Aero-Works's Avatar
We reloaded the attachment.
Thank You
Rocco / Aeroworks
File Type: pdf
Aero-Works is offline
Old 01-16-2012, 09:47 AM
yaron_k
My Feedback: (45)
Thank you
I appreciate that.
P.S
which engine would you choose for the .60-.90 version?
A Saito 100 or an OS 120AX?
I have both
yaron_k is offline
Old 01-22-2012, 01:17 PM
OobedoobeR
you 100 saito will do well. i have a 91fs on mine with no problems and i mounted as far forward as possible to help with the cg.
OobedoobeR is offline
Old 01-23-2012, 11:37 AM
yaron_k
My Feedback: (45)
Will go with that
yaron_k is offline
Old 04-03-2012, 09:36 AM
twostroke
twostroke's Avatar
I am putting a 82 saito on the 40-60 size should I place this as far forward for help with cg or is this not an issue on the smaller one?
twostroke is offline
Old 04-03-2012, 09:38 AM
DoubleDD
my planee of the same size has a .46 Evo and it needs lots of nose weight to even come close
DoubleDD is offline
