RX-18 in a Mato sherman?
Old 02-01-2011, 11:23 AM
Alex4182
Alex4182's Avatar
Default RX-18 in a Mato sherman?
Ok....I thought I had this under control. I was going to hook up a new RX-18 board to my Mato Sherman using its stock receiver, plug everything in, and go but NO! I tried that and some smoke came out of the receiver from a resistor. Ilooked again at the wiring from a diagram on here and noticed the ref. and gnd. were in the wrong spot so I swapped the wires on another receiver I had and tried again. This time I got a good pop from the green resistor on the receiver and a ton of smoke.
Why is this doing this? Do I need something else to hook up an RX-18 board? Aparrentally I will need 2 new receivers since I have 2 tanks Iam working on so what should I get?</p>
Old 02-01-2011, 11:51 AM
diabolic-mind
Default RE: RX-18 in a Mato sherman?
id say go with all HL electronics then it is compatible. even if you have the positive and negative wires connected to the right spots its possible that the voltage is different.
Old 02-01-2011, 01:17 PM
Alex4182
Alex4182's Avatar
I see. After a little more research Ifound that same answer. The Heng Long board just won't jive with the Mato receiver. Next question; Does anyone have 2 of these withthe 3 pin cablelaying around they want to sell me? RCcommand, which is right here in TX, isn't answering their phone and I want to pick up some gear boxes from them as well.
Old 02-01-2011, 02:05 PM
harleridr
Hi Alex
We have a few tankers here in C.C.,TX. What part of S.A. are you located.
Harle
Old 02-01-2011, 02:11 PM
Alex4182
Alex4182's Avatar
I can see Sea World from my driveway if that helps.
Old 02-01-2011, 02:56 PM
SgtPearce
ORIGINAL: Alex4182
LOL!!!!!HAHAHAHAHAthats funny
Old 02-01-2011, 06:35 PM
Rebellion13
Rebellion13's Avatar
ORIGINAL: Alex4182
I see. After a little more research I found that same answer. The Heng Long board just won't jive with the Mato receiver. Next question; Does anyone have 2 of these with the 3 pin cable laying around they want to sell me? RCcommand, which is right here in TX, isn't answering their phone and I want to pick up some gear boxes from them as well.
RCCommand from what ive heard is not in business anymore, and I wouldnt recommend buying from them anyway. http://www.rctankwars.com Phil can get you whatever you need, and great customer service, as many others can attest to.
Wade
