How to solder like a Pro - on a budget
Old 04-16-2011, 08:14 PM
dragnse7en
Banned
Default How to solder like a Pro - on a budget
<p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:">I have written this for anyone new or inexperienced to the world of soldering. I worked many years at a couple of electronic companies as a certified soldering tech, and I want to share my knowledge with anyone out there that may need help. First, I have written a brief summary on how much is enough to spend on tools and supplies. The second part is a list of the tools, as well as descriptions and suggestions for the proper tool and why it should be used instead of something else. The last section, aside from some notes, covers a typical soldering operation in five steps.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:">Tools: </span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:">Below is a list of necessary tools required for soldering electronics, at a minimum but adequate budget and inventory. Please try not to substitute or omit anything listed below, because soldering is something not to be short-cutted. If one takes short-cuts soldering, they will often find themselves soldering all over again. Let&rsquo;s do it the right way the first time! </span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:">You may already have some of the tools listed below, but assuming that you do not, try not to spend over $65-70 for everything. That amount of money should last your entire lifetime in this hobby. Try and spend no more than $40 on the iron, $12 on solder, $6 for rosin flux, $3 each for the pliers and wire strippers, $4 for the insulation materials, and $3 on cleaning supplies. The small file or emory board and sandpaper can be found at the local dollar store. You may already have some of the tools mentioned below, and most likely chances are that you already have the cleaning supplies. Also, it never hurts to ask a friend to borrow the necessary tools, as long as they&rsquo;re returned on time and are nice and clean.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:">Here are the required tools:</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal">Soldering<b style=""><span style="font-size: 10pt; line-height: 115%;"> Iron:</span>[/b]<b style="mso-bidi-font-weight:normal"><span style="font-size: 10pt; line-height: 115%;"> </span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:">Avoid any iron less than 40 watts. Try and find a good one that has been made in the USA &ndash; for real; the quality of the iron and the quality of its tips made in the USA are significantly better than the quality and grade of metal they make in China or anywhere else, and the heating element and tip will not wear out as easily. Be sure to purchase an iron that has replaceable tips &ndash; if it doesn&rsquo;t have it, shop somewhere else. Future regret will haunt you later on if you need to solder a part, only to discover that the tip is too large for the connect surface, for the sake of this argument. You should not have to spend more than $40 for this, but if you see a better deal, grab it.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><b style=""><span style="font-size: 10pt; line-height: 115%;">Solder</span>[/b]<b style="mso-bidi-font-weight:normal"><span style="font-size: 10pt; line-height: 115%;"> and Rosin Flux: </span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:"><span style="mso-spacerun:yes"></span>There are many types of solder out on the market, and it is important to select the right one for your hobby. Look for lead-free solder for electronics, as this is the best type I have used throughout my many R/C hobbies. Buy a tube a rosin flux, and not the other types. Acid flux and regular flux emit corrosive gasses during the soldering operation, and may damage electronic circuits. Flux, for soldering, acts as a cleaner when heated, and is also a catalyst to help the molten alloy and the different metal bond together.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:">Pliers and Wire Strippers: </span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:">Pliers are an invaluable tool for soldering. Not only do they keep you from burning your fingertips, they act as a third hand holding and assisting during the soldering operation. I sometimes use an elastic or rubber band to secure the handles and make sure that they have a strong yet delicate grip on the part. There&rsquo;s no need to go out and buy a set of robo-grip mini vise action pliers; a simple set of flat grip needle nose pliers is more than enough for this hobby. That goes for the wire strippers too. It would be overboard to buy a set that has all the industry&rsquo;s gauges preset on them. The strippers that look like angled shears are just fine.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:">
Fine sandpaper and File: Some prep work may need to be done on the solder connect surfaces, and some fine sandpaper and a small file or emory board will speed up the work of exposing new metal for a surface for the solder to bond.
</span></p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:">Insulation materials: </span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:">You never know what you will need to patch up or cover after a soldering operation, so you need to have a minimum of at least a roll of electrical tape and a set of 2 inch assorted heat-shrink tubes. A roll of electrical tape and two feet of 12 gauge heat-shrink tubing cost about the same price at around $2.50 each.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:">Cleaning Supplies:</span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:"> I don&rsquo;t like to leave all my solder work messy, and there are times when parts and surfaces need to be cleaned and prepped. A bottle of isopropyl rubbing alcohol and cotton swabs and cotton balls is a great thing to have while soldering and it&rsquo;s friendly on electronic circuits because it evaporates rather quickly.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:">All of the above mentioned tools and supplies required for soldering can fit inside a shoe box or similar sized container, and shouldn&rsquo;t take up much space on the workbench. Now that we have the parts that need soldering, and all the rest of the tools, let&rsquo;s begin.
</span></p><p class="MsoNormal"><span style="font-size: large;"><b style=""><span style="line-height: 115%;">Typical Steps for Soldering:</span>[/b]</span></p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span>[/b]</p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:">Step One: </span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:">Set up all your tools and supplies on the workbench, and have any manufacturer&rsquo;s instructions available for reference if necessary. Before turning on the iron, make sure that the tip is nice and clean. If not, then clean it with a sponge and some diluted rubbing alcohol with water. Turn the iron on, <u>and wait at least 5 full minutes</u> before use. Be sure to clean the iron&rsquo;s tip before and after the iron is used for that day. When the tip is unusable or cannot efficiently transfer heat, then it <u>must</u> be replaced. Heat is very important for soldering, and I will emphasize that throughout this article.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:">Step Two: </span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:">Pre-form all terminals and strip wire ends. Wire ends only need to be stripped away about 3mm; anymore and the wire may have a tendency to break. Please try to resist using a razor as a substitute for wire strippers, because you will cut away half the strands in small gauge wires. I do that once in a while, only if I am in a pinch, and I still cut off a couple of strands. The more the strands in the stack the better; after all, all the strands together make up the gauge of the wire!
Cut the heat-shrink tubing to a desired length if necessary, and pre-install them onto the relevant wires. Pull the heat-shrink tubing all the way down to the opposite end of the wire. Pre-fit and crimp any small terminals to small wires. <b style="mso-bidi-font-weight:normal"><u><span style="color:red">FOR BATTERIES &ndash; WORK ON ONE WIRE LEAD AT A TIME TO AVOID AN ELECTRICAL SHORT &ndash; ESPECIALLY STRIPPING AND PREFORMING.</span></u>[/b]<span style="color:red">
</span>Also for wires, preform the strand ends by making sure that the whole stack is straight, even, and has a blunt end. When that is finished, gently twist the wire to make the whole stack of strands into a mild spiral, keeping the stack straight.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:">Step Three: </span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:">Tin all solder contact surfaces; both terminal ends and wire strands. Tinning is a method used to create a pre-formed bonding surface to make soldering easy, clean and strong. Add a small dab of rosin flux to your finger, and cover the entire connection surface with it, and wipe away any excess. The result should be an even and thin coating on the entire area where the solder is going to bond. Heat up the surface that will be used for the solder connection for about 5-8 seconds. Once the surface has thoroughly been heated, add a small amount of solder to the surface. If the part is properly and evenly heated, the molten solder will flow evenly throughout the surface.
Be careful, because flat surfaces will tin faster than non-flat ones. There should be enough of a layer of solder on the surface to cover the whole area. A good example of tinning a flat surface would be about a layer of solder about half a drop of water in size and at least 0.5mm thick (a strong yet thorough coating). Pay attention to the amount of heat that you are applying to the surface; too hot, and you can destroy surrounding electronics and their own solder connection, and the solder you're applying may run off. Too cold, and you will not be successful. There is an industrial term known as a cold solder (a noun), which I will cover later.
Tinning a wire without a solder pot is still easy. Again, apply rosin flux to the entire strand stack and wipe away any excess, again looking for an even and thin coat throughout. Pay attention to the amount of heat that&rsquo;s applied to the strand stack, holding the tip to it for about 8-12 seconds, and then add the solder. Let the molten alloy flow evenly through the stack, all the way down to the insulation. It is perfectly okay to let a little of the flow to go past the insulation; it actually helps prevent the wire from breaking in that area. Allow all tinning to cool on its own. Do not blow on it or cool it down any faster than it will on its own. This is the number one cause of a cold solder.
If smoke is getting in your face and burning your eyes, move your face farther away from the work, or turn a fan on and point it away from your work space. Put the fan on the side and not behind you as that will defeat the purpose. Don&rsquo;t let the fan blow towards the work space as it may unevenly cool the part you&rsquo;re trying to heat.
Wires and terminals usually need the assistance of the pliers, as you can imagine how fun it would be to burn yourself while juggling a strand of solder, the iron, and the part you&rsquo;re trying to heat all at once. I would usually use the elastic or rubber band to secure the handles, so that my part won&rsquo;t fall out if I bump the pliers with the iron.
Remember &ndash; gravity is also your ally, and if the tin flow isn&rsquo;t reaching an area where you want it to be, just tilt the part in the direction you want the flow to go. After the part has been properly tinned and cooled, the solder connect surface should look shiny and even throughout, and have a thin layer of solder coating all over the connect surface.
When the surface is cooled, clean it with a cotton swab and rubbing alcohol, and let it completely dry before moving on.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:">Step Four:</span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:"> Reflow and/or solder the connections. If you tinned two parts together, you can solder the connection together using a method called Reflow. Put the parts together as they should be, either via manufacturer&rsquo;s instructions or obvious sense, and hold the tip of the iron to the middle of both parts, right where they join, and hold the tip there for around 5-8 seconds. Flip the parts over and repeat on the reverse side. The solder will re-flow (hence reflow) and thin layer of alloys with melt together and into each other, creating a conductive and mechanical bond between the two parts.
After the parts have cooled properly, test the joint by gently twisting or wiggling the two parts. If they move, add heat again as described above, and add a small amount of solder right at the joint where the two parts meet, and in a place where the solder will go inside both parts. Let it cool down and test it again.
For small wires and terminals that may need a solder joint, apply some rosin flux to the area that needs solder, and this time it&rsquo;s okay to not wipe all the excess away &ndash; wipe away about half of it. Apply heat to the preformed connection for no more than 5 seconds, then immediately add a very small amount of solder. The result should be a nice flow that gets sucked right into the end of the terminal and wire.
After you let it cool down, clean up all the solder joints and connections with the rubbing alcohol and swabs or cotton balls.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;line-height:115%;font-family:">Step Five: </span>[/b]<span style="font-size:10.0pt;line-height:115%;font-family:">Install the terminals into their housings; insulate any exposed areas with the heat-shrink tubing or electrical tape as necessary. <u><span style="color: rgb(255, 0, 0);">BE SURE TO CHECK THE POLARITY OF THE TERMINAL AND HOUSING BEFORE SEATING IT IN FOR GOOD!</span></u> Typically, a terminal is correctly seated into the housing when you feel a pop or hear a tick, depending on the type of terminal. Use a small flat blade screwdriver to assist the terminal and get it seated.
I use a cigarette lighter to shrink all my heat-shrink tubing, and I use a small dab of shoe goo at the end of the piece of electrical tape to keep it on there (although I know electrical tape is for temporary use).
Lastly, take a once-over look at all the soldering work done, and clean any left-over rosin flux or smoke burns from the heat-shrink tubing with rubbing alcohol and a cotton ball. Looks professional, eh?
</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:">Done!</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:">Cold Solder - a cold solder joint occurs either when the alloy is just hot enough to flow but then cools when it travels away from the heat source (the solder is not hot enough), or when the soldering surface becomes cooler than then molten alloy. This results in very tiny fissures and pits in the joint, which makes it very weak. These cold solder joints can be corrected immediately by a reflow operation, but pay attention to the amount of heat that is applied! Let the area cool itself down to be safe before the reflow.
I do want to note that there are many, many other tools used for soldering, such as solder suckers, hot plates, solder pots, silk screening and solder paste, wave machines, and so on. We don&rsquo;t really need those things when we need to solder in this hobby, and for those on a budget, the simplest of the tools will do just fine for the job.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:">Another important note to mention is that some connectors and plugs come with the terminals pre-molded into the housing. A perfect example would be a set of W.S. Dean&rsquo;s plugs. My best advice is to pay attention to the amount of heat that&rsquo;s applied because if the plastic gets warm, the terminals will move and get out of their proper alignment. One solution to that problem is this: Connect the set of plugs together, after they&rsquo;ve been cleaned and prepped. This way, the housing on the far end of the solder work will help hold the terminals in their proper alignment. This does not mean you get to ignore the heat. Any pre-molded connector will be prone to softening from a soldering iron. Pay close attention to how you are holding the iron too, and keep the heating element that&rsquo;s under the tip away from your soldering operation.</span></p><p class="MsoNormal"><span style="font-size:10.0pt;line-height:115%;font-family:"></span></p><span style="font-size:10.0pt;line-height:115%;font-family:">I sure hope that this article is helpful to those who are looking for some good soldering tips and pointers. I typed out a similar article and tried to post it, but my session timed out and I lost the whole thing, and had to re-write it all over again. If you have any questions, problems or comments related to soldering in this hobby, feel free to post it here, and if you need any more help please PM me and I will help you out the best I can, aside from hitching a ride to you and showing you in person 8)</span> <span class="info"> </span>
Old 04-16-2011, 09:49 PM
aftermarket
Default RE: How to solder like a Pro - on a budget
Thanks for that super informative write-up. Will come in handy when I get around to shortening my esc wires.
Old 04-17-2011, 02:26 AM
Haddi Taha
Haddi Taha's Avatar
Thanks for the depth instructions for soldering, i'm crap at soldering. I am getting the stuff you stated and going to follow the step so i can do my first proper soldering job (Last soldering job i just stripped to wires and wrapped them around each other then insulated them)
Old 04-17-2011, 10:36 AM
The Mad Modder
The Mad Modder's Avatar
Nice writeup. You should point this out to RCKen or one of the moderators to be made into a sticky. That way there's a place to point people when they want to learn.
ORIGINAL: dragnse7en
Soldiering Iron: Avoid any iron less than 40 watts. Try and find a good one that has been made in the USA
Wall Lenk is a good company to look at for irons. They make good irons in several wattages from 25 to 150 watts.
They're US made, too.
Old 04-17-2011, 10:53 AM
dragnse7en
Banned
ORIGINAL: The Mad Modder
Thanks! I was thinking of asking it to be stickied as well. Lenk is a solid company, and I think that they cater to the midwest and CA, b/c I've seen them but never used them at work. We used mostly Honeywell and some GE equipment.
I will PM RCKen and ask him if he will sticky this. Thanks again all 8)
Old 04-17-2011, 10:55 AM
electricrc68
Banned
just letting you know that you spelled soldering wrong. you put soldiering.
Old 04-17-2011, 11:04 AM
dragnse7en
Banned
ORIGINAL: electricrc68
GGGHHHHHFFFFAAAAWWWWWW!!!!!!!!! See what seven years of active duty and three tours in Iraq will do? Thanks - I will edit the body of the article. Nice eye!
* okay - I think the grammar is fixed.
Old 04-18-2011, 06:51 AM
Foxy
Foxy's Avatar
I don't know if anyone did send a note to Ken, but I would suggest there's no need. While I would normally seek his approval before stickying something, I can't possibly imagine him having any objection to this great article. Therefore I'm stickying it now. Fantastic writeup, good work!
Old 04-24-2011, 12:54 PM
Umar M
Umar M's Avatar
wow this is really a great artical... i'm a complete novice when it comes to soldering, i would normally apply a blob of solder to the iron it self and then chuck it onto what ever needed soldering... if i may suggest purchasing a helping hands station, they are quite useful and you can get them for a cheap price on ebay as well ($5-ridiculous amounts). thanks for the super post, i'm going to book mark this and link my friends to it
Old 04-24-2011, 01:55 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
If you are on a real budget all that is needed is a $10 radio shack soldering iron, and $2 roll(the $6 spool has like 8X more solder) of rosin core solder
That is it
BTW why avoid irons under 40 watts?
My main used iron is a 30 watt and I've been soldering for over 20 years (had my cheapo radio shack for 16 or so years)
Only thing you need higher wattage for is batteries IMO, and if you are just doing batteries $20 300 watt iron would probably be best seeing it can solder those in less than 15 seconds
Old 04-24-2011, 04:06 PM
dragnse7en
Banned
ORIGINAL: SyCo_VeNoM
That is it
Well, in my 26+ years of experience soldering, a 30 watt iron doesn't cut it; it won't solder thicker terminals or bullet connectors right. If it works for you, then good for you.
Also, there's a huge difference between being cheap and doing something correctly on a budget.
Old 04-24-2011, 04:59 PM
electricrc68
Banned
* okay - I think the gammar is fixed.
i know this is pretty late to say this, you spelled grammar wrong too. You forgot the R.
<br type="_moz" />
Old 04-24-2011, 05:17 PM
dragnse7en
Banned
Thanks. Threw the r in there.
Old 04-24-2011, 08:19 PM
Ttam Says Blarg
Ttam Says Blarg's Avatar
Nice writeup! 5 stars!
Old 04-25-2011, 02:32 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
That is it
well note I said for batteries (and meant to say bullets) I use a $20 300 watt iron to do it in 15 seconds. You CAN do it with the 30 watt, but it takes forever. Seriously a Turnigy 10, and 8 gauge battery wires I will say forget that won't be soldered with the 30 watt unless you are very patient (took me 10-12 mins to heat the wire up the one time I did it). But down to 16 AWG I find the 30 watt is more than enough
Also I solder more than just batteries, and bullet connectors I occasionally will make PCB's, and solder IC's so I need the lower power.
Old 04-27-2011, 03:04 AM
Haddi Taha
Haddi Taha's Avatar
anyone tried putting deans on turnigy 8 gauge wires?
Old 04-27-2011, 07:54 AM
dragnse7en
Banned
That would be a pretty tight fit. The diameter of that wire is about 3.26mm, and the terminal ends are 4mm. I would split the strands in half and then sprial them up again, and solder them to both sides of each terminal. Strip the insulation ends a bit more so that the strands can seperate and bend around in a better fork-like shape.
Old 07-27-2011, 10:11 PM
Haddi Taha
Haddi Taha's Avatar
thanks dragnes7en
Old 10-18-2011, 02:04 PM
Foxy
Foxy's Avatar
ORIGINAL: Haddi Taha
I've done it a few times now, getting good at it, I'll do you a vid next time if you'd like
Old 10-18-2011, 03:08 PM
dragnse7en
Banned
ORIGINAL: Foxy
That would be cool. I should have thought about doing the same thing, because I was putting together a bunch of deans plugs together two days ago.
Thanks!
Old 03-10-2013, 07:27 PM
digitalsmithy
great stuff here!</p>
Old 03-21-2013, 04:11 PM
Salinas Hawk
Should the iron have an internal or external heating core?
Old 02-19-2014, 03:29 PM
pvalvo1
Hey guys, Im new and was wondering how i con make a new thread. Thanks
Old 02-19-2014, 11:22 PM
R32GolfTA06
In the main forum area you click on create new thread
