can I split a ignition cuttoff?
My Feedback: (65)
I amall but complete ona B-25 with evolution 10cc engines, and read through threads that I can split a excell cuttoff. I have a heavyduty switch, the excell cuttoff, then y harness(heavyduty) then ignitions
Has anyone tried this?
jason</p>
RE: can I split a ignition cuttoff?
Yes you can do that. The typical CDI units draw about 1 ampere maximum (more like 650ma), so since the RCexl ignition kill switch is designed to handle several amps, it won't be a problem. The RCexl switch uses a <span style="FONT-FAMILY: Arial"><font size="2">20V<font size="2">,</font>16 Amp, MOS-FET (IRF7465) on its<font size="2"> </font>output</font></span>. You could even do it with four engines too.
