Covering an under cambered wing
My Feedback: (27)
I have almost ready to cover a Ben Buckle kit of a Lanzo Record Breaker. This is a huge old timer kit. It has an under cambered wing. With a normal wing I tack down the covering around the parameter holding the covering tight then I shrink it up. I can’t do this with an under cambered wing. I think I have to start tacking down the covering to the wing spar and work my way back.
I am looking for any tips and ideas from this great knowledge base on here to cover the bottom of the wing.
Pete
Pete
I do it the way you described however once the bottom covering is shrunk I apply some adhesive inside the wing at the corners between the ribs and the covering. Not sure it is necessary but I see it as insurance against the covering pulling away at a later stage.
For adhesive I usually brush some PVA type with a small brush, on both sides of each rib but not quite the whole length of the rib, the middle portion is more significant.
I have also read but never actually tried it, that it is advisable to apply the shrinking heat from the hot air gun from above the bottom covering. I don't see why it would matter but it was written by a very respectable British modeller.
My Feedback: (68)
Great choice in oldtimers,I've been flying mine for over 20 years.Your exactly right,you cover from the inside and work your way out.Use balsa rite,or some kind of heat activated adhesive for some extra holding power.Start at the spar,secure it down length wise,then carefully work the fabric back.Temp is kind of crucial,you want to activate the adhesive,but you don't want to shrink the fabric,a trim iron works great.Let the fabric flow back to the outside of the wing,you don't want to be pulling the fabric,let it fall into the undercamber.Take your time,patience will pay off.-jeffo
Banned
Use woven fabric and glue it fron the inside of the wing structure or sew it on like full size airplanes.
How much camber are you talking about ?
Zor
Zor
Banned
After reading your desires above I can only wish you the best of luck to end up with a cambered airfoil and take advantage of its high lift characteristics.
I know what I would do if I was the builder - finisher.
Regards, Zor
My Feedback: (404)
When covering, use normal heat and iron down where covering meets ribs first. Using balsarite can help adhesion. The trick is when shrinking, be carefull to just heat up the areas that need shrinking, take you time and don't heat up quickly all over. Also may help to have a cool wet rag handy to help keep pressed down and attached to ribs.
