need advice for a zenoah G-45
DE
have a zenoah g-45 i got in a trade.converted it to electronic ignition and removed all the spring starter parts but 1.manual says it is a G450PU.i want to remove the race the 1 way bearing rides on.in the manual it shows the rear of the crank as having a taper and key.i'm thinking i need a puller.others say there is a nut.been lookin for a week,no nut.any advice out there?.thanks for any help
you will probably need to apply some heat to the threaded on sleave as it probably has been threaded on with threadlocker. Lock the crank apply heat with a heat gun (a torch may get too hot and damage the seal) and rotate the sleeve counter clockwise
