Axe 100 SS whos familiar with "Tags" setup
AR
I'm new to the "Tags" stabilization. I understand not to use any trims in your radio. Heli drifts pretty bad to the left in hover. I have to keep constant pressure to the right to hold a stable hover. I know all helis will move around but this takes off to left instantly if sticks are neutral. Anyway to adjust this out? I've tried adjusting the linkages but doesn't make a difference. I noticed the tags board had lifted a little from the foam tape on one side so I put a zip tie around it to hold a little pressure to where it is laying even but still didn't make any difference.
