Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
Jetcat P120 constant "Pump Running" lit
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 02-22-2022, 07:25 PM
rcnats
My Feedback: (56)
rcnats's Avatar
Default Jetcat P120 constant "Pump Running" lit
I have a P120 that has the kero start conversion. First time hooking everything up to check out the system and the "Pump running" lamp is lit on the GSU and the I/O board. According to the manual, this means the glow plug is defective. However, I have the system in Kero start mode with the Kero plug installed. Changed out all cables with a new set. Same indication. Please help. Thanks.
Old 02-22-2022, 09:56 PM
Dave Wilshere
Only a flashing red light means a failure. Solid red light means pump running…
Old 02-23-2022, 05:41 PM
rcnats
My Feedback: (56)
rcnats's Avatar
Okay, the flashing red light means defective glow plug (in the manual). Does this apply to a kero-start plug?
Old 02-24-2022, 11:46 AM
Dave Wilshere
Yes.
Old 02-24-2022, 11:48 AM
Dave Wilshere
Does the pump run if you go through to the test menu?
Any noise from the pump when the red light is on?
Old 02-24-2022, 07:23 PM
rcnats
My Feedback: (56)
rcnats's Avatar
Pump does not run. This happens when I first turn it on. I have a P80 with a kero plug. I will swap them out and see if that is the problem.
Old 02-24-2022, 10:02 PM
Dave Wilshere
I think there is a fault on one of the ECU boards.
Old 06-18-2022, 05:58 AM
Instructor
Instructor's Avatar
What version ECU ae you running?
Larry
