Nitro slash shock springs
Old 05-13-2024, 06:33 PM
tazzzz
Question Nitro slash shock springs
I have a TRAXXAS NITRO SLASH,,,I’m installing a set of BIG BORE SHOCKS,,,,,it comes with the red dot springs,,,,not completely red….they seem a little stiff for this truck,,,any good suggestions for the perfect springs for these front and rear shocks? Thanks guys
Old 05-14-2024, 04:12 PM
suburban_hooligan
suburban_hooligan's Avatar
you can't know the perfect springs until you drive it. if it's bouncing off the ground when landing jumps, or gets tossed all over creation on whoops it'll need a softer spring. if it's not rebounding quickly enough when landing jump's or bottoming out really hard on small jumps, or slapping the chassis on uneven surfaces it'll need a stiffer spring. the perfect spring will depend on how you drive it and on what surfaces. give those stock springs a shot and see what happens.
to further complicate things you could also have the correct spring and need to adjust the shock piston or oil weight.
