Help on identification
Old 12-08-2003, 06:48 PM
Mystery
Default Help on identification
I'm new to this forum. I just found a RC pickup truck in my dumpster. It has these 2 bars of white metal, they look as if you took some metal bars and put some white powder on it. A wire plugs into each end of each bar. What is this? Is it some corrosion on something? And if it is corrosion what is it on?
Old 12-08-2003, 07:19 PM
LosiFan
LosiFan's Avatar
Default RE: Help on identification
Sounds interesting. Can you post pics of it on here?
Old 12-08-2003, 07:28 PM
Mystery
I don't have my digital camera here right now so I'll try and describe it more thoroughly. On the back it says 10W0.22, then the omega symbol(Olms)(sp?) then K. It's in a little metal housing above the motor gearbox. So it says 10W0.22QK, but omega instead of Q.
Old 12-08-2003, 09:15 PM
LosiFan
LosiFan's Avatar
Sounds like a mechanical speed control, but I can't be sure without looking at it.
Old 12-09-2003, 12:29 AM
i8tweety
i8tweety's Avatar
It sounds like you may be describing a 6 cell stick pack battery that's corroded. Are the "2 bars of white metal" cylindrical?
Old 12-09-2003, 08:02 PM
Mystery
No. This isn't like any other batteries I have seen before. They are rectangular, and the wire plugs right into the metal itself, not like a batteries. Also It already has a battery pack. The wires from each battery plug into a turntable-thing that has a servo under it, and many wires sticking out from different sides. The wire from the reciever goin to the turntable, as well at that from the battery.
Old 12-10-2003, 07:32 PM
dg2b
Like phatsub said, it sounds like an MSC.
Old 12-10-2003, 08:29 PM
LosiFan
LosiFan's Avatar
He's describing what sounds a lot like a friend of my Son's old Rustler. It had an MSC that I replaced with an ESC.
Old 12-11-2003, 09:37 AM
Unstable
does it look kinda like this but with blade connectors instead of wires?
