Schulze Slim 105He in Piccolo Pro
Hi
I recently bought Schulze Slim 105He for my Piccolo Pro.
According to the manual
1. The maximum length between the battery and the speed controller should not exceed 20 cm (page 6).
2. The maximum length between the speed controller and the motor should not exceed 12 cm (page 6).
The Piccolo Pro boom length is 32 cm. Therefore, in order to satisfy both restrictions, I have to place the speed controller in the middle of the boom.
Where do you recommend to place the 105He in the Piccolo Pro?
Shanti
Shanti
RE: Schulze Slim 105He in Piccolo Pro
Just put the speedy somewhere on your main frame. Keep all your weight as close to the center as possible. The tale motor draws very little current, so in your case i wouldn`t worry about the 12 cm restriction. It will work perfectly fine. Just make sure your solder connections are good and you will be alright!
Phil
Phil
