angle incidence on UCD 60.
RE: angle incidence on UCD 60.
Hi, the thrust angle on the motor mount is a trial and error thing. You are looking for about 3 degrees +/-. Not knowing how thick the washers are you can't tell how many to put in. You have to adjust it, fly it and see if you need more or less. Quantum Models sells "Earnst" thrust plates. For under $3.00 a pack it gets you three plates.
1-3 degree plate.
1-2 degree plate.
1-1 degree plate.
It doesn't get any more acurate than that and you don't have to worry about the washers compressing into the wood on the firewall and changing the thrust angle. Different engines = different thrust. Trial and error. Good luck, Joe
1-3 degree plate.
1-2 degree plate.
1-1 degree plate.
Magic, a .60 or .46 ? What engine and prop? The .60 with a Saito 100 swinging a 15/6 without thrust angle compensation, under full power, will circle the field in a left hand pattern hands free. Forget about up lines. I'm curious as to how you do it. Joe
TN
how does this effect the plane if you don't do it at all.
mine is a 60 size and i have a ys 110 with a 15x6 prop, and i did notice that when i was going verticle the plane wanted to go left, and i added trim to the rudder and it really didn't help much but i have only flown this plane one time i will add some right thrust and see if that helps. thanks
